Fairphone 3+ does not power on
Hello there,
I have a Fairphone 3+ and today it turned off randomly, and it won’t turn on again.
It does not give any life sign and does not show up on $ lsusb on my laptop
I tried the following:
charge it with Laptop and power brick <= 3A & >= 1A
clean USB-C Port
checked the connections inside and the power button
removed the battery
Does anyone know where the problem could be?
best greetings JoniG59
hey,
It could be that your battery is bad, because the fairphone wont boot if the battery not present or not working properly.
Do you have another battery to try and switch them?
I’ll have one on Thursday, thanks for replying and giving one possible solution
this wasn’t the issue with another working battery the device won’t give any life signs too
You mean it is the same with the new battery?
yes i do the new battery changes nothing
Yes sadly your problem form the start didn’t seem like a battery issue.
Regarding the internal connections have you tried cleaning the earthing contacts between the display and core module. The ‘solder’ contacts outlined in red on the display.
For more mention of these contacts see, but they are outlined in blue in that topic
