Hello, my mobile does not charge anymore. I do not know why. The charger I use is the same that I use with my laptop where it works perfectly well.
I have cleaned the USB port and still not charging.
Any ideas please?
Hi and welcome to the forum
I suggest you search for similar as there are many thoughts and to repeat them is a pain
Same issue here. If I plug my phone when it is on, no charging… It charges only when I turn it off, and then plug it onto the charger and chord. Annoying as Hell… Been like this since an update I believe, some time late October.
Hi!
I have just received my new fairphone 3. The battery was about 40% charged when I received it. But I haven’t managed to charge it! I bought a new usb-c cable, tried from 2 different computers and charger. Now the phone has switched off! I tried taking the battery out for half an hour and plugging the phone in again but that didn’t work.
I have run out of ideas. ANy suggestions before I take it back to the shop?
Thanks!
Una
yvmuell
Split this topic
June 4, 2022, 6:57pm
3
