my PH2 Bottom Module is broken.
[edited] The microphone doesn’t work.
In hands free mode, I am able to call [edited]
Living in The Netherlands.
NB: To be able to send a direct message to the user , you will need to reach trust level 1 by entering/opening at least 5 topics, reading at least 30 posts and spending a total of 10 minutes reading posts.
Be aware, that cross-border shipment of batteries outside a phone is virtually impossible for individuals .
amoun
February 10, 2023, 9:33pm
2
There may be a possibility to repair it. You don’t say what is wrong.
https://forum.fairphone.com/search?q=bottom%20repair
Ah thanks for the hint - microphone is broken.
I see one topic of someone who repaired, but…
martinc
February 11, 2023, 9:22pm
4
Correction: I have yet to attempt a repair myself, I’m first looking for a backup bottom module in case my efforts go awry. You might want to check this thread, it beings with repairing cracked solder for the µUSB port and has talk about replacing the microphone about midway through:
@JohnHughes (thanks again) send me two broken bottom Modules some days ago. This one has a defekt µUSB port.
After disassembling I took a picture with a microscope camera and found some solder cracks. Barely to see without magnification. Two cracks at the shield contacts that I am not too worry about, but also one at contact 5. I am sure that was a slack joint. Some serious force must be acted to the Port.
I will try to resolder the joints and hope the bottom module will be able to do its work…
system
Closed
February 18, 2023, 10:55pm
6
