Dynamic wallpaper (Muzei) is replaced by default one after a while
I’m a new owner of a FP5. I’ve installed the Muzei wallpaper app and enabled it on both my homescreen and lockscreen. When I setup it from the Android Settings app, it seems to work, but after a few hours the lockscreen come back to the default wallpaper (dark blue with shapes). There are no issue with the homescreen. Also note that I have enable the feature to turn on the screen when double tap on the screen.
What I tried so far:
  • Disabled battery optimisation on the muzei app
I find one other topic that might be somewhat related:
On the other hand, some issues on the Muzei github repository suggests that some brands disable this feature (I doubt that it is related, as it is half working on my case):
  • github .com/muzei/muzei/issues/636
  • github .com/muzei/muzei/issues/150
Does anyone else experience that? Do you have any suggestions? Is there another optimisation that I should disabled?
