Disconnected broken fingerprint sensor to make phone usable. Thank you Forum!
In short:
Fingerprint sensor broke so phone did not operate reliably.
Tanks to some threads here; I learned how to easily disable it.
(I used thin insulation tape on the sensor contact pads, reachable after removing main board.)
(Search forum for fingerprint sensor)
Longer history:
I dropped my fp3 and unfortunately it hit a sharp stone with the fingerprint sensor.
Result: phone froze, and reader got very hot.
Battery out & in, charger connect. Sensor hot but not as much.
Phone booted, after some attempts, very sluggish, and fingerprint reader do not work.
By some hours sensor was less and less hot, and phone usable, but sometimes sluggish and sometimes failed booting. Sensor never works.
I guess whatever got short circuited burnt off, or he supply to it broke down nicely.
And the system tried in vane to communicate with the sensor but did not handle bad communication well.
I read in support that sensor is part of main module and that cost too much to replace.
I needed a bit better camera and performance anyway so i bought a fp5 (with murena /e/os) and decided to try to fix my fp3 later to be my new spare phone.
Now, I finally searched this forum (should have done that to begin with! )
And your information here helped me fix it in ten minutes!
So thank you forum members for the threads, and the organisation for he forum! :pray:
Just remove or reset your fingerprints in the software?
As it even had problem booting i do not think removing fingerprint data would help. I guess the OS stumbles when initialising it. Anyhow it was easy to physically disconnect it. Saves battery power too.
Could be something for others to try if they only have boot problem and not power drainage / hot sensor.
No. This is hardware level. Most importantly it used obscene power. Secondly the phone somehow could not even start up. Could maybe be unstable power, but i suspect problem initialising the system when sensor works erratically - but works when totally absent.
