Data on SD card not readable/card not recognized after few days or restart
hi @Plant cool checkout, thx mic
Just chiming in – sorry, no solution…
SD Card formatting is apparently a complicated procedure, not akin to HD formatting. The SD Card Association offers a free SD Card formatting utility (Win/Mac) which supposedly does it right. Explanations on that page.
Since you’re reformatting again and again, you might want to try that (although I don’t think it will fix this specific issue, which might be due to a bad contact in the SD tray).
Thanks for suggestion, through it indeed does not solve the issue.
Used the tool to format the 128 GB card, it wiped out everything, served the card to my fairphone, it did not like it and wanted to format again, so formatted, copied very few sample data, restarted the phone and it wants to format again.
Since the 32 gb card works just fine and there is no size difference between the two (like 128gb one being thinner), it cannot really be due to bad contact. I think the issue is within Fairphone firmware not able to handle sdxc cards properly.
Maybe the smaller capacity card needs less current to work properly? Just wild guesses here.
I do understand your frustration.
Update from me (also using a 128gb SD card) tried adjusting some settings and formatting again, saved a sample photo onto SD card. Oddly it shows up in storage settings as a preview but can’t move it to internal storage (‘File not found’, and shows up blank in Fairphone Gallery & Google photos.
Restarted phone to find, lo and behold: SD cards needs formatting once again!
Think I’ll give up trying to make this work for now. Hopefully fairphone can fix this in future.
I would say submit a ticket if you did not already - if more people report the issue, there is higher chance they will actually fix it.
Just a curiosity - which card manufacturer do you have? I wonder if all sdxc cards do not work or whether some brands actually do work, explaining why there are not many reports (or maybe many people do not use sd cards at all).
An update:
Support ran out of ideas and wants to send the phone back for repair, while I do not think this is a hardware issue (and do not have a working alternative right now).
Found another 64 GB kingston card and when I insert it into my phone it connects it just fine - it just creates the system folders it wants but otherwise no formatting required. This is what I would expect from the phone to do with pretty much any card with data, but seems it likes some cards and hates the others.
While I was digging through forum about sd card problems, I ran into some guides that also include list of compatible and not compatible cards (based on user testing) - sadly there are only older fairphones - there was also a very short list for fairphone 5 somewhere, but nothing for fairphone 6 around. I can only assume that whatever worked in older phone may work also in newer one and vice versa (some people just transferred their old card into their new fairphone and it worked).
Maybe it would be good to start a list for fairphone 6? For now I can say that:
Kingston MicroSDHC 32GB Class 10 - working fine, no folders created* (Plant)
Kingston MicroSDXC 64GB Canvas Select UHS-I, U1 -* working fine, creates bunch of system folders (Plant)
Kingston MicroSDXC 128GB Canvas Select Plus - seems to work, requests formatting only if card does not contain any folder (Plant)
Kingston MicroSDXC 256GB Canvas Select Plus
Gen3 - seems to work, no formatting required with sample data (Plant), random issues so far without data loss
Samsung 256 GB - worked fine for 1-2 years, then failed in multiple devices (Colofornication)
Sandisk 512 GB - worked fine for 1-2 years, then failed in multiple devices (Colofornication)
these two may also be the other way around
ADATA 128 GB Premier Class 10, UHS-I, V10 - not working - requires formatting on each reboot, corrupts data in 1-2 days if not restarted (Plant)
MyMemory PLUS 256GB 4K A1 UHS-1 V30 U3 - not working - formatting required (puddlesplash)
MyMemory 128 GB? - not working - formatting required (puddlesplash)
samsung 128GB (model?) - worked before, now requires formatting? (Bogey) more details needed (may be compatible but at end of life or random issue occured - same as kingston 256)
Info from other people what they used and works/does not work for them would be appreciated. For now I can only guess that getting a new kingston card may solve my issue.
An AI generated table assembling available information about which card worked on which fairphone (excluding Fairphone 6):
Card-FP2stock-FP2custom-FP33stock-FP3custom-FP4sto.pdf (133.8 KB)
In my eyes its “normal” that not all SD cards work in all devices, in the past we had Lists here in the forum. I e.g. never heard anything about ADATA cards and the word “Premier” can most likely be added to what indicate its premium?
We had several discussions also for other FPs I suggest to do some search and reading.
In my case this is maybe the second time I ran into a card not working everywhere I put it (first case being 3d printer not able to read exfat formatted card). It’s a normal card that can be still bought in the local shop (although it was at half the price when I got mine), there is apparently also a faster “premier pro” version (bigger one).
From reading through other posts (I possibly read most of the sd card related posts on this forum) it seems to me that it may be safest to get a kingston/sandisk/samsung card, which seem to be working in most cases (kingston confirmed) and pray for no issues.
Why cannot it simply work like the 7 years old devices, which officialy support only 64 gb cards but happily can use the 128 gb card as well. :downcast_face_with_sweat:
Update: Found a 128 GB kingston canvas card and it does not require formatting as long as there is at least one folder (only data are ignored). Since all kingstons that got into my hands actually worked, I bought a 256 gb one to use in the phone and so far no signs of issues (~1 day running, few restarts etc.).
It seems that Fairphone loves kingstons, hates Adata and no clue about anything else. Sad, since getting a “special” card for the phone is totally against Fairphone’s goal to limit overconsumption and electronic waste (not going to toss the card, but if it worked, I would not really buy a new one in the first place). Also kind of limits competition if you have to stick to certain card producers anyways.
Seems the issues with sd cards still are not over.
Now I have the 256 gb kingston inside. I can read pretty much anything on the card and it seems nothing got lost, also no requests to format it after every restart, like with the adata one.
But now I found out that I cannot really write anything on it using the phone. Photos save nowhere if sd card is selected as default storage and even file browser never copies anything (either gets stuck at 0% or reports some permission errors).
I am sure the 32 gb card worked (but is sdhc), did not try to copy anything on the 64 or 128 gb ones. Possibly I am dealing with more problems than just card incompatibility. More investigation needed (maybe reformatting will help?).
Update: Took the card out, connected into my computer, windows complained that there are issues with that unit, so I let it repair, also renamed the card to “External”, as Fairphone somehow wanted that name. Put it back, now able to copy data to the card and the photo saves. Let’s see for how long.
We are possibly dealing with 2 separate issues:
  1. Formatting request on each restart, data corruption. - Bad firmware support (Adata only). Easy to test in ~<5 mins.
  2. Cannot write to card, photos do not save anywhere after some time, permission issues (but data not dissappearing). - Both Kingston 256 and Adata. Needs at least ~1-2 days of testing.
    SDHC card (Kingston 32) got neither of these issues.
Seems that the Dutch are dealing with the second issue as well (from what translator told me).
Today the card became unresponsive - neither of the apps was able to read any data on it. It just never loaded (even the file browser got stuck), so restarted the phone (took extremely long to boot it) and seems to be working again with all the data.
So it seems there are still issues every ~2 days.
Hi, I am having issues with my sdcard (samsung 128GB) as well. Just realized that my card is not detected anymore. Works well when I read it from a PC, but my fairpyone 6 doesn’t detect it or, when it detects it, it wants me to format it, for some reason. The card was working fine a few weeks or months ago, not sure when the issues started, as I don’t use it much. Maybe when I upgraded my OS?
hi @KurtF , solutions for Windows and Mac are done, but can you suggesting a Linux Tool Kubuntu 26.04 LTS KDE- Plasma? the systems MTP- Tool for a 256GB SD- Card (SDHX Class 10) from Intenso only for using in my Android Handsets. ext4 formatting or an other file format? friendly regards, mic
I’m afraid not… The specificity of that tool was just that it was created by the SD Card Association, and they are supposed to know the little secrets of their products.
As long as they don’t create a Linux version there won’t be one and you’re left with the standard Linux formatting tools, and the caveat that I don’t know how well Linux handles exFAT, which is a proprietary Microsoft format after all.
If I were you I would try using the official SD Card formatting tool under Wine. It might not work but it’s worth a try.
Will do. Brand I’m using is My Memory
Update:
After some exchange and my request to forward the adata compatibility issue to their tech departement, the Fairphone support acknowledged there is some issue with adata card, although they do not know why, while kingston cards seem to be working.
They also pointed to this forum, stating that if there are more reports of the same issue (or upvotes on those), there is also a higher chance they may do something about it, as they are not able to test everything themselves. Okay understandable. While this forum is not an official way to report issues, they are apparently checking the hot topics.
Provided them link to this topic once more and description of the recent issues with kingston card (although minor compared to the adata incompatibility), so let’s see what happens next.
Anyways getting a kingston card seems to be pretty safe workaround for those who need to use an sd card. Also updated the list of working/not working cards including an assembled table from previous fairphones, more reports welcome (relying only on kingston may not be the best).
Update:
Phone runtime ~121:42, Kingston 256 gb inside, I noticed a popup saying something like “new sd card detected, please set it”, which I dismissed, but could not access anything on the card, so went to settings → storage, selected sd card, “this storage is damaged”. Hmm, so familiar message. Rebooted the phone, sd card normally detects, seems all data there. What the hell?
Update:
Issues with sd cards were also reported to cause random phone shutdowns or restarts and card replacement solved the issue, but it is currently unclear which cards caused the issues nor whether it was not a sign of card damage. But I would not be surprised if these were another incompatibility symptoms.
hello @KurtF :waving_hand: thanks for your suggested workaround! but in the meantime, my Linux- Distro is compromised by this vulnerability, discovered in the night from Monday/ Tuesday 26.10- 27.10.2026 that’d destroy RedHat Enterprise, KVM’s and so many more! I gave another distribution a chance to avoid annoying AI/KI- Exploits! hopefully but no clues whatever you setting up, fighting against AI/KI Exploits & 0-Day Vulnerability is a ever loosing match, they can working so fast & perfect perform the timing … uff. please hold your dumbs, that I can find a good solution for extreme Security and also Anonymous Pen testing! friendly regards, mic
:thinking: Which one? I only know about a vulnerability affecting VMs, which means shared server environments. Unless you’re managing a server farm you’re quite safe, the end is not near! :smiley:
To quote The Hitchhiker’s Guide to the Galaxy: “Don’t Panic”!.. Firstly, hacking has moved from random mischief to an extremely lucrative (and thus highly organized) criminal market with high profit expectations, which means they only target high-value targets. Why hack Joe Bloggs when for the same effort you can hack somebody or something who will yield you millions. It’s a stupidity which will get you fired (quite literally in this case).
So, unless you’re a company and/or rich in something potentially valuable, or an investigative journalist or a politician, chances are the criminal industry will simply ignore you: Not worth the effort. Some second zone script kiddies might eventually cast a large net for low-hanging fruit, but those you usually can avoid by keeping all your devices patched, since they won’t use 0-days and complicated vulnerabilities, but simply cheap old exploits many people haven’t bothered patching.
(I expect to be told to stay on topic, but this had to be said) :man_shrugging:
hi Mr @KurtF you’re right! the only thing to starting Kubuntu LTS 26.04.xx Plasma 6.5 KDE is starting from my USB- Life stick, and download patches in the short persistent Spaces & perhaps copy then the file’s in the Murena- Cloud (if it works proper?) wanted to check, after the /e/OS- updates. thanks for spending your time with me! a Viennese Fairphone :baby_angel: Angel, will prepare another Linux- Distros on 2 Laptop Devices, the plans with/ how/ what do to will discovered in a Discussion/ Brainstorming before the procedure came up in the future! so long! mic
