So the solution is to take the cushion off and to then then dip a paper towel in some IPA, just enough to have it not drip. You then wipe the mesh on both sides, so that the mesh is thoroughly impregnated with the IPA, and the inside of the cup with as well. You then wait about half a minute. This way the earwax has some time to dissolve. Once that time has passed, you wipe it all with the same paper towel a second wipe, which will remove the earwax. I use one towel per earcup. The IPA does not damage the materials of the earcups.
