Camera doesn't work after update
I got my FP3 two weeks ago and worked fine. But last week, I updated it to Android 9 as recommended. Since then, the camera doesn’t work: it won’t open. It says “Camera systematically stops”.
The only way to take a picture is within the Whatsapp.
Does anyone have the same problem?
Anyone would have an idea on how to solve it?
Cheers
Without further ado, here’s your solution:
Side note to avoid confusion … The Fairphone 3 comes with Android 9, but this Android 9 of course gets updated over time.
Thanks @urs_lesse, it did fix the problem!
Great!
