https://play.google.com/store/apps/details?id=com.lvonasek.tofviewer appears to be gone. Anmy idea of why, or where to acquire it now?
Since you state that SafetyNet passes, is that by defaultâthat is, without Magisk? Additionally, does Google Pay work? I do not believe that my installation of CalyxOS on my Pixel 3 passed SafetyNet.
Yes, by default. I think they added safetynet support like half a year ago or so, but not sure.
About gpay, I do not have or use it but I think on the microG Github they say the newer version, based on flutter, works. Though no garanties.
My banking apps all work fine though (Germany)
sounds interestingâŠ
Strange that the app has disappeared from the Playstore. You can still get it here:
But, would that be a good idea to download it from this source?
After CalyxOS and LOS, Wide Angle now also works in iodéOS for all third-party apps. ![]()
Depends upon the reason that it was removed, and whether APKPure is trustworthy. I donât know the answer to either confoundry, but I am thankful for the link.
On the developerâs website, his app is still mentioned. Unfortunately, there is no reason why it was deleted from the Play Store.
If someone dares to install the app from APKPure, feedback would be nice if the night vision photos or videos work with LOS, CalyxOS or iodĂ©. Then we might know if the TOF sensor works. If it doesnât work, though, it doesnât say much, as it could also be because the app doesnât work with the FP. Officially, the app is only compatible with a few specific smartphones.
On Calyx the app at least doesnât crash, but it doesnât show anything useful either.
It does however take beautiful pitch black photos and videos ![]()
It is difficult to say⊠Either the app is really not compatible or the TOF sensor does not work. ![]()
I think the TOF sensor still has to be made available via Camera2 API. Iâm quite sure that I even read about this topic somewhere in the depths of this forum some months ago.
I tried building this project , but I think it was when I was still using FPOS. Maybe this could be a good starting point for experiments if someone is interested and enthusiastic enough. But again, I donât think we will have much success as long as Fairphone isnât exposing the sensor and they will likely have bigger topics the next years. I just installed âCamera2 API Probeâ from the PlayStore and the TOF sensor isnât even mentioned.
edit: iodéOS 4 (Android 13) here
edit2: Itâs even written in the first post of this topic, likely I read it just in this thread:
edit3:
Back home I took a closer look at the project I linked. Thatâs not the one I tried. The one I built had different color outputs depending on the distance, varying from green to red, if I remember correctly.
Do you also have only Camera ID 0 to ID 3?
It is clear that there has been no access to the TOF sensor. However, CalyxOS made a patch for the camera (bypassing the SYSTEM_CAMERA authorization check) in early December. The hope was that this would make not only the wide angle camera usable, but also the TOF sensor. But unfortunately it seems not to be so. ![]()
So we have to depend on Fairphone again after all. But they have not even managed in 2 months to adopt the finished (!) patch from CalyxOS in their FPOS. That they will solve the other camera issues (mentioned in the first post here) on their own I donât think is realistic by now. They are already completely overwhelmed with all the other software issues and updates/upgrades to FPOS. ![]()
Weâll probably have to be satisfied with the fact that of all the camera issues mentioned, only the usability of the wide-angle camera has been solved. Which was, after all, the most important point (for me).
On iodĂ©OS itâs:
0 - back
1 - front
2 - back
Camera 2 API Probe report
Model:FP4
Manufacturer:Fairphone
Build:13
SDK:33
Camera ID: 0
Camera Facing: BACK
Hardware Support Level:LEVEL_3
Manual exposure:1
Auto exposure:1
Auto exposure, always flash:1
Auto exposure, auto flash:1
Auto exposure, auto flash, red eye reduction:0
AE Lock:1
Compensation Range: [-12, 12]
Compensation Step: 1/6
Target FPS Range: [4, 15]
Target FPS Range: [15, 15]
Target FPS Range: [4, 30]
Target FPS Range: [7, 30]
Target FPS Range: [30, 30]
Manual focus:1
Auto focus:1
Auto focus macro:1
Auto focus continuous picture:1
Auto focus continuous video:1
Auto focus EDOF:0
White balance off:1
Automatic white balance:1
WB: cloudy day:1
WB: daylight:1
WB: fluorescent:1
WB: incandescent:1
WB: shade:1
WB: twilight:1
WB: warm fluorescent:1
AWB Lock:1
RawCapture:1
BurstCapture:1
availableCapability: BACKWARD_COMPATIBLE
availableCapability: CONSTRAINED_HIGH_SPEED_VIDEO
availableCapability: RAW
availableCapability: YUV_REPROCESSING
availableCapability: PRIVATE_REPROCESSING
availableCapability: READ_SENSOR_SETTINGS
availableCapability: MANUAL_SENSOR
availableCapability: BURST_CAPTURE
availableCapability: MANUAL_POST_PROCESSING
Stabilization Mode: Video
previewSize: 3952 * 1824 (13:6)
previewSize: 3840 * 2160 (16:9)
previewSize: 3264 * 2448 (4:3)
previewSize: 3200 * 2400 (4:3)
previewSize: 2976 * 2976 (1:1)
previewSize: 2880 * 2156 (720:539)
previewSize: 2688 * 1512 (16:9)
previewSize: 2560 * 1440 (16:9)
previewSize: 2340 * 1080 (13:6)
previewSize: 2048 * 1536 (4:3)
previewSize: 1920 * 1440 (4:3)
previewSize: 1920 * 1080 (16:9)
previewSize: 1600 * 1200 (4:3)
previewSize: 1440 * 1080 (4:3)
previewSize: 1280 * 960 (4:3)
previewSize: 1280 * 768 (5:3)
previewSize: 1280 * 720 (16:9)
previewSize: 1080 * 1080 (1:1)
previewSize: 1024 * 738 (512:369)
previewSize: 1024 * 768 (4:3)
previewSize: 864 * 480 (9:5)
previewSize: 800 * 600 (4:3)
previewSize: 800 * 480 (5:3)
previewSize: 720 * 1280 (16:9)
previewSize: 720 * 480 (3:2)
previewSize: 640 * 480 (4:3)
previewSize: 640 * 400 (8:5)
previewSize: 640 * 360 (16:9)
previewSize: 352 * 288 (11:9)
previewSize: 320 * 240 (4:3)
previewSize: 240 * 320 (4:3)
previewSize: 176 * 144 (11:9)
photoSize: 3952 * 1824 (13:6)
photoSize: 3840 * 2160 (16:9)
photoSize: 3264 * 2448 (4:3)
photoSize: 3200 * 2400 (4:3)
photoSize: 2976 * 2976 (1:1)
photoSize: 2880 * 2156 (720:539)
photoSize: 2688 * 1512 (16:9)
photoSize: 2560 * 1440 (16:9)
photoSize: 2340 * 1080 (13:6)
photoSize: 2048 * 1536 (4:3)
photoSize: 1920 * 1440 (4:3)
photoSize: 1920 * 1080 (16:9)
photoSize: 1600 * 1200 (4:3)
photoSize: 1440 * 1080 (4:3)
photoSize: 1280 * 960 (4:3)
photoSize: 1280 * 768 (5:3)
photoSize: 1280 * 720 (16:9)
photoSize: 1080 * 1080 (1:1)
photoSize: 1024 * 738 (512:369)
photoSize: 1024 * 768 (4:3)
photoSize: 864 * 480 (9:5)
photoSize: 800 * 600 (4:3)
photoSize: 800 * 480 (5:3)
photoSize: 720 * 1280 (16:9)
photoSize: 720 * 480 (3:2)
photoSize: 640 * 480 (4:3)
photoSize: 640 * 400 (8:5)
photoSize: 640 * 360 (16:9)
photoSize: 352 * 288 (11:9)
photoSize: 320 * 240 (4:3)
photoSize: 240 * 320 (4:3)
photoSize: 176 * 144 (11:9)
videoSize: 3952 * 1824 (13:6)
videoSize: 3840 * 2160 (16:9)
videoSize: 3264 * 2448 (4:3)
videoSize: 3200 * 2400 (4:3)
videoSize: 2976 * 2976 (1:1)
videoSize: 2880 * 2156 (720:539)
videoSize: 2688 * 1512 (16:9)
videoSize: 2560 * 1440 (16:9)
videoSize: 2340 * 1080 (13:6)
videoSize: 2048 * 1536 (4:3)
videoSize: 1920 * 1440 (4:3)
videoSize: 1920 * 1080 (16:9)
videoSize: 1600 * 1200 (4:3)
videoSize: 1440 * 1080 (4:3)
videoSize: 1280 * 960 (4:3)
videoSize: 1280 * 768 (5:3)
videoSize: 1280 * 720 (16:9)
videoSize: 1080 * 1080 (1:1)
videoSize: 1024 * 738 (512:369)
videoSize: 1024 * 768 (4:3)
videoSize: 864 * 480 (9:5)
videoSize: 800 * 600 (4:3)
videoSize: 800 * 480 (5:3)
videoSize: 720 * 1280 (16:9)
videoSize: 720 * 480 (3:2)
videoSize: 640 * 480 (4:3)
videoSize: 640 * 400 (8:5)
videoSize: 640 * 360 (16:9)
videoSize: 352 * 288 (11:9)
videoSize: 320 * 240 (4:3)
videoSize: 240 * 320 (4:3)
videoSize: 176 * 144 (11:9)
Camera ID: 1
Camera Facing: FRONT
Manual exposure:1
Auto exposure:1
Auto exposure, always flash:0
Auto exposure, auto flash:0
AE Lock:1
Target FPS Range: [8, 30]
Manual focus:1
Auto focus:0
Auto focus macro:0
Auto focus continuous picture:0
Auto focus continuous video:0
Auto focus EDOF:0
White balance off:1
WB: cloudy day:1
WB: daylight:1
WB: fluorescent:1
WB: incandescent:1
WB: shade:1
WB: twilight:1
AWB Lock:1
RawCapture:1
BurstCapture:1
Camera ID: 2
Camera Facing: BACK
Manual exposure:1
Auto exposure:1
AE Lock:1
Target FPS Range: [2, 15]
Target FPS Range: [2, 30]
Manual focus:1
Auto focus:1
Auto focus macro:1
Auto focus EDOF:0
White balance off:1
WB: cloudy day:1
WB: daylight:1
WB: fluorescent:1
WB: incandescent:1
WB: shade:1
WB: twilight:1
AWB Lock:1
RawCapture:1
BurstCapture:1
@max_o It is strange that there is no ID 3 with iodé A13. @hirnsushi has ID 3 with Calyx A13. (And both have the camera patch running.) See his camera2 report:
I must have made a mistake with camera ID 3. I read about LOGICAL_MULTI_CAMERA on the Android site: A logical multi-camera consists of 2 or more physical cameras. Now I would interpret ID 3 to mean that this logical multi-camera consists of the main camera (ID 0) and a camera not mentioned (before the decimal point). This could possibly be the TOF sensor. Because the super wide-angle camera (ID 2) should not be a problem to be displayed. But still, there is no entry before the decimal point.
Excerpt from @hirnsushi report:
Camera ID: 3
Camera Facing: BACK
Physical Camera Ids: [, 0]
Hardware Support Level:FULL
[âŠ]
availableCapability: LOGICAL_MULTI_CAMERA
[âŠ]
I will do a reset and a clean install switching from beta to stable, probably at the end of the month. Maybe this will change something, otherwise I will have a closer look at the according changesets. I always try to avoid this as much as possible since Iâm not that much of a driver/hardware guy. ![]()
With the camera patch of CalyxOS there are camera IDs 0 to 3 with Calyx itself, with iodéOS only 0 to 2. How does it look with LineageOS?
Can someone create a report for this with Camera2 API Probe and post it here?
It would be interesting to know if ID 3 is also missing there.
LineageOs 20:
Model:FP4
Build:13
SDK:33
Camera ID: 0
Camera Facing: BACK
Manual exposure:1
Auto exposure:1
AE Lock:1
Manual focus:1
Auto focus:1
Auto focus macro:1
Auto focus EDOF:0
White balance off:1
WB: cloudy day:1
WB: daylight:1
WB: fluorescent:1
WB: incandescent:1
WB: shade:1
WB: twilight:1
AWB Lock:1
RawCapture:1
BurstCapture:1
Camera ID: 1
Manual exposure:1
Auto exposure:1
AE Lock:1
Manual focus:1
Auto focus:0
Auto focus macro:0
Auto focus EDOF:0
White balance off:1
WB: cloudy day:1
WB: daylight:1
WB: fluorescent:1
WB: incandescent:1
WB: shade:1
WB: twilight:1
AWB Lock:1
RawCapture:1
BurstCapture:1
Camera ID: 2
Camera Facing: BACK
Manual exposure:1
Auto exposure:1
AE Lock:1
Manual focus:1
Auto focus:1
Auto focus macro:1
Auto focus EDOF:0
White balance off:1
WB: cloudy day:1
WB: daylight:1
WB: fluorescent:1
WB: incandescent:1
WB: shade:1
WB: twilight:1
AWB Lock:1
RawCapture:1
BurstCapture:1
Camera ID: 3
Camera Facing: BACK
Manual exposure:1
Auto exposure:1
AE Lock:1
Manual focus:1
Auto focus:1
Auto focus macro:1
Auto focus EDOF:0
White balance off:1
WB: cloudy day:1
WB: daylight:1
WB: fluorescent:1
WB: incandescent:1
WB: shade:1
WB: twilight:1
AWB Lock:1
RawCapture:1
BurstCapture:1
Thanks for the super fast report!!! ![]()
OK, so LOS has the camera IDs 0-3 just like Calyx. All entries in the report are the same. It is really strange that only iodé is missing the ID 3. ![]()
Hello, Iâm Alice from NĂźmes in France. Iâm about to by my first smartphone! And it ll be a Fairphone of course! But Iâm a bit worried about the camera because itâs important for me to be abble to make good pictures. So my question is : should I wait until some improvements concerning this point are made or do you think it works much better now than at the Beijing and I wonât regret my purchase? Sorry for my english, I m just french!
Iâm not sure what you mean with âat the Beijingâ, but IMO the camera is almost completely useless when it comes to taking pictures of things in motion. If everything is completely still, itâs fine.
