When browsing www.fairphone.com, I regularly see problems on the site / bad german translations.
I want to help make the site work better, and after I just discovered the “Eagle Eye” badge on the forum today, I’m even more motivated!
So, let’s start. I’m going to split this list into two parts:
1st: Problem part. Here we have problems that encounter on the site (it’s possible that they only occur in German, since I don’t want to update my preferences to every laguage all the time)
2nd: Bad German translation part. This is acutally pretty obvious.
PART 1 - PROBLEMS
- If you are at “Was wit tun”, the “Erfahre mehr darüber” button beneath the FP2 should lead to the cost breakdown, but it just reloads the page.
- Same page as before. The “Erfahre mehr darüber” button underneath “Triff das Team” doesn’t fit to the other “Erfahre mehr darüber” buttons
- If you set your language to German, in the top left corner it says “DE”, but with a british flag beneath it (btw, if you fix this, could you make a german and austrian flag please ;))
- At the shop, while scrolling down, there are three different version of the “Buy” button: “Zur Wunschliste hinzufügen”, “Warteliste” and “Jetzt kaufen”.
- The page “Ersatzteile” 404 - doesn’t exist.
PART 2 - BAD GERMAN TRANSLATIONS
- At the checkout, if your cart is empty, the text “Sie haben keine Artikel in Ihrem Einkaufswagen.” appears, which is the polite form of German. At the rest of the page, the ‘normal’ form is used.
- At the shop, at the “Alles drin: Top Leistung, extra Vorteile” section, it says “Zwei Sim-Karten-Steckplätze für die Arbeit oder die Reise”, which is technically correct, but sounds weird.
- At the “Geschenkkarte” page, it says “Fairphone-Geschenkkarte Von 10€”. “Ab 10€” would be correct german.
- At the “Unsere Ziele” page, it says “Besser ist besser gemacht; Unser Smartphone erzählt eine ganze Geschichte: Über diejenigen Menschen, die es geschaffen haben.” Write only “die” instead of “diejenigen”.
- At the “Unsere Ziele” page, at the bottom, it says “See who shared our story” and “Our partners”, which is (obviously) not german.
- At the “Was wir tun” page, it says “Unser Ziel ist es, jedes einzelne, im Fairphone verbaute Teil im Auge zu behalten – vom Anfang bis zum Ende.” Leave out the “,” after “einzelne” (very high-level criticism)
- At the shop, at the technical specifications, it says “Datenvolumen, soviel du willst”. I would replace “Datenvolumen” with “Speicherplatz”, since your Datenvolumen is how much mobile data you have per month, which could be misleading.
To be fair, I don’t know how this site is translated, but it’s probably done by this crowd-translation-everyone-translates-a-single-sentence-thingy, which is probably good for apps, but not good for websites, because you have context here which the translators don’t know, so sometimes strange things happen.
Maybe @Douwe could forward this to one of your website-maker-nerds
to improve the website
