Android 16 - Cropped picture with 2x zoom
Having the same problem, I will try the Pro workaround until a proper fix is released. It’s such a shame this bug is happening. Thanks!
You could try a third party camera app like open camera or Camera FV5. They habe manual controlls and you can experiment in settings to get besr results.
Same problem here for a while, I’m a professionnal photographer and it’s a big problem, please fairphone fix it !
If thats the case I rather assume using pro mode is always the better way to go.
it is actually, but i did not find a way to directly open the app straight to the pro mode, especially when i need to photograph very fast.
Ok I see, that not possible I think when the camera App was closed, It should work when its just put in the background.
Camer fv5 has all the manual controlls you need straight from the start and if you using a power button shortcut to activate the cmera tou can choose it as your default one. You can even swap for wide angle camera there, but not 2x zoom ,which makes me wonder if the camera api is tweaked in stock app to crop pictures to 2x, which would explaon bad framing
I should also mention that this app is free with limitation of picture resolution and some more advanced options , but its fairly priced , I use it on 2 of my phones and photos coming out ok for my use, which is not professional photography, but i do medle with iso and metering and also white balance sometimes to get the best shot.
The camera on my Fp6, running the latest Android, is doing something strange. If I zoom to 2X, it will crop further, to something more like 4X, It more or less doubles the zoom at any length beyond 2X. If I take it down to 1,9X, it works as intended. Have I done something weird to the settings? Can’t for the life of me find a fix.
There is a thread already about this bug:
I guess yours can be merged into it.
I am glad I joined the community forum today as this cropping issues annoys me a lot. I am now very careful with the kind of zooming and a number of nice scenes have been lost already.
So I wonder: I could not find any Fairphone responses to this thread - is the fairphone team not listening in on these discussions. Am am a dedicated fairphone fan - but not seeing any official response is not a way to advertise for the product.
This forum is not monitored by Fairphone themselves. Any issues can be reported directly to them - not on this forum.
This forum is for the community. Fairphone mentions that problems should be reported on their support page opening a ticket. Then you get in contact directly with them.
I had already reported this when I opened this post. I’ve reported the problem again. I encourage other users experiencing the same issue to do the same.
No need to report multiple times by the same user.
Hi! Just found this after too many months with this issue. Just wanted to check in here so I can get notified in case any of you found it solved someday.
I’ve seen the same issue on my FP6 since the Android 16 update. The preview looks fine, but the saved photo can be much more cropped. Hopefully this gets fixed soon.
In case you haven’t seen, an easy workaround for now is to use the ‘pro’ mode with everything set to auto. It functions like the regular camera but doesn’t get cropped.
Anybody knows if this issue has been resolved yet? I still come home from conferences with worthless photos of slides, because I forgot to switch to pro mode.
I vaguely remember an issue with the scene AI detection being mentioned in one of the patch notes. I haven’t actually tested it yet, I’ve gotten so used to using pro mode.
Well nevermind, I just tested it and the first photo I took was immediately cropped so it’s not fixed. Ridiculous honestly, pretty crazy to let the main camera just be broken like this for months on end.
