Works play, stop, volume down and volume up with original FP Audio Adapter?
I want to buy the original Fairphone USB-C to Mini Audio Jack Adapter. However, it is important to me that I can control the sound output through the headphones.
If you use the buttons on the cable of the headphones, does play, stop, volume down and volume up also work?
I’m not sure this can be answered with yes or no, I think it depends on the headset as well, my Apple earphones e.g. did not work with my FP2
The original Fairphone USB-C to Mini Audio Jack Adapter works perfectly! You can change the volume as you like and play and stop also work. :slight_smile:
Maybe it doesn’t work with every headphone? I don’t know. I tested it with this one:
