Does anyone have a recommendation for wireless earphones that will work with the FP3? I have bought Beatbuds Pro because they were recommended for Android but they keep cutting out, work very intermittently.
Someone posted a list of compatible earphones for FP2 years ago, is there a list for FP3?
Thank you
I cannot give a recommendation, but you might be interested to hear that among the rumours about what Fairphone will present on 30 September are also “True Wireless Earbuds”. If this materializes, I could very well imagine that these might work with the FP3 as well.
I bought Sennheiser model M3IETW2 C, earbuds with active noise cancellation. They work very well with my FP3.
Best regards Paul
I am using EarFun Air Pro earbuds. Cheap, but good - working fine with my FP3.
