Wifi connection NOK (LineageOS for microG
FairPhone 4 running LineageOS for MicroG (version 23.0.20251103-micrG-FP4)
French FREE Wi-Fi network
My phone no longer connects to my personal Wi-Fi network (FREE) at home.
When I go into the Wi-Fi settings, everything looks fine and it says “connected,” but it’s not working.
Thanks in advance.
I see that your phone recently received an update.
You will likely find that other Wi-Fi networks continue to function but please inform us if that’s not the case.
I think the first thing to try is deleting just your home network and connecting again.
It’s possible that the settings of your Wi-Fi router need to be adjusted, in particular for security and encryption. Are you familiar with how to adjust your router settings?
Apart from that your problem might be resolved by a reset of Bluetooth and Wi-Fi. If you do that, make sure that you have a note of all your Wi-Fi passwords since all BT pairings and saved Wi-Fi networks would be deleted.
You might also ask in the Lineage community
In the “Network & Internet settings > Private DNS” menu, I unchecked ‘Automatic’ and checked ‘Disabled.’
My Wi-Fi connection is now restored.
Many thanks
