WiFi Calling enabled but no WiFi calls
I enabled WiFi calls on both SIMs, but neither works, so how come?
I have the problem that I can enable WiFi calling, but it doesn´t work. In Flightmode Wifi can be enabled and also WiFi-calling, but it give the error message that for calling I have to deactivate Flightmode. So what?
Are you also with German Telekom? Are you also missing the detailed settings?
No, I have the settings and I am in Austria. But what I found out: FP6 is not yet supported by A1 oder Spusu (3). How long could it take until that will work?
Ask your provider.
Here in Germany, as yvmuell told, German Telekom doesn’t support wi-fi calling and therefore this settings in the phone are disabled.
On my fp6 with o2 provider here in germany wi-fi calling settings are availabe and I tested, it works in flightmode with wi-fi enable.
So if settings available and it do not work there are differences what your sim-card say to the phone and what your provider do.
Do you come from another mobile and has it worked on this one?
thats not fully correct: Wifi-Calling is supported with Telekom DE in general, you just dont have the detailed settings.
Yes, on my FP4 all of my 2 SIMs worked with wfif calling. I didn´t know that this function is device dependent…
