Is there a way to get a Widget/shortcut for battery save mode on home screen? The one that comes with the OS.
There is a widget called “Settings” or similar, 1x1 with a gear symbol (in German it’s Einstellungsverknüpfung). Add it to your home screen. It opens a popup list of functions and settings to choose from.
Does it contain what you are looking for?
A more elegant, but also more complicated solution would be to use GravityBox to edit the QuickSettings tiles.
You’d need root and XPosed, if you don’t know what that is the settings widget is probably better.
With GravityBox you can add a battery icon to the pull down menu. One click on this activates battery save mode.
Perfect! Thanks! Though it would be even better with a one touch widget.
