Where is the square icon for switching between active apps?
I have recently upgraded from an FP3 to an FP6. One thing I can’t see on the newer version is the square icon at the bottom right of the screen which could be used to display all active apps (or do a screen grab). Does such a functionality exist on the FP6?
hello
there are two types of navigation - gestures and 3-button navigation.
Unfortunately I cannot check on my FP5 right now, but the google help suggests
System->Gestures->Navigation mode
What you mean should be 3-button navigation.
That works perfectly. Thank you! :smiling_face:
