When OTG connect to Barcode Scanner
When my Android Phone using OTG connected to Barcode Scanner then I will not able to use the soft keyboard.
Any solution or setting that I can do?
Thanks in advance.
Regards,
Garry.
I found the solution already. Thanks.
Great to hear. What was the solution? Maybe other users have the same issue in the future and your experience will be of help to them.
