When connecting to Laptop all folders of FP2 are empty
I have a FP2 (Android Version 6.0.1) and a Laptop with Windows 10 Home.
Out of sudden when connecting the FP2 with my laptop via USB I do see all the folders (Music, Pictures, Videos…) but they are all empty. I tried different connection modes (MTP, TPT…) but it didnt’ change. I saw different folders then, but they were still empty. There is definitely music in the “Music” folder and there are definitely pictures in the “Pictures” folder.
But when I copy music in the “Music” folder I can see these files.
Hope anybody can help!
Clear the cache of “Media Storage”. This should trigger rebuilding of the list of contents on your FP2.
I emptied the “Cache data” in “Internal storage”. That didn’t help.
Or did you mean sth else with media storage?
To be honest, I haven’t got an FP2 right now. I think you need to go to Settings > Apps and find “Media Storage” there. When you select it, you should get the option to clear/empty the Media Storage cache.
under Settings-Apps there is no such a thing like “Media Storage”. I checked a couple of Apps (Photos, Camera…) there and their caches are also pretty empty.
I finally found the exact instructions:
Go to Settings > Apps > (touch the 3 point in the up-right corner) Show System processes (or something like that, I translate from french) > Media Storage > Storage* > Clear DATA.
Source: USB file access (MTP) not longer working after upgrade - #10 by Geoff
Thanks a lot!!!
Now all the pictures are visible on my laptop. Music not - strange enough… but thats not a big problem.
Thanks again for your help :slight_smile:
