Xqua
October 1, 2015, 8:12pm
1
I fucked up my jack female plug (headphone plug) on my fairphone, and looking at it, I can clearly unsolder it, and put a new one in place.
I would just need the exact model so that I can buy it and replace it !
Anyone knows the exact model / dimensions for the female Jack connector ?
I know about this topic:
Sure thing. I bought this one http://www.ebay.de/itm/131365292450?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
it fits as for the size more or less (had to sand off the little plastic pins on the side) and the contacts are pretty much at the right spot, although they are bent to the wrong side of the jack. As for fixing it in position I used 4 tiny points of hot glue - be very careful with that because you dont want to get any of this on the connectors for cables.
Which has one, but it’s not the exact one.
Anyone knows the exact one ?
Thanks
Stefan
October 1, 2015, 8:18pm
2
Have you contacted support about this? It is a very specific question and I think they may be more able to help you with this question.
Xqua
October 1, 2015, 8:19pm
3
I did not, I though I’ll try the common knowledge of human brains first ^^
I’ll shoot them an email !
Also, this info should be public !
Stefan
October 1, 2015, 8:21pm
4
Yeah it should. However most people will buy a new mainboard instead of soldering the headphone jack.
I think the link above with the Sony Xperia L headphone jack is the only common knowledge the community can offer…
Xqua
October 3, 2015, 1:43am
5
So, I am fairly certain that the connector is that one:
http://www.linkconn.com/en/product/9d7d2930-a3e8-4b64-9fbb-41611e08b12f
Anyone with connexions to suppliers >< Because it is not online anywhere XD
jftr
October 3, 2015, 11:24am
6
The easiest and cheapest option might be to get a used or broken mainboard and reuse the part you need. If you think you are able to solder it onto the mainboard, then you should also be able to remove it from the old mainboard.
Finding an old mainboard might be easier than getting the spare part if it is not available online.
Stefan
October 3, 2015, 3:27pm
7
Fairphone support might be able to provide you with a broken main board.
Xqua
October 3, 2015, 10:10pm
8
Thanks, that is a great idea indeed !
I contacted support to see what they say about it !
Any chance you guys know of someone with a broken Motherboard ? ^^
Stefan
October 4, 2015, 5:47pm
9
There were some posts with broken phones / phones as spare parts repository here:
https://forum.fairphone.com/t/unofficial-second-hand-fairphone-marketplace/6453
