Watertight case and qi2 for Fairphone
I search for a wathertight case and some qi2 support so that my mobile phone wont get waterdamage.
i always charge trough the wathertight case. its sad that fairphone can’t make these acessories or a slightly less easy to open but repairable watertight phone.
lets face it i had an iphone 5 for 7 years
first died the battery
then the the software
and after that the screen because oft water damage
last the charging connector because of physical exhaustion and water damage
so that are my 4 main painpoints to avoid
Hi @4893uihjkd
Welcome to the Fairphone community form.
Which Fairphone do you have or are you interested in?
If i remember it right, Fairphone have shared that they wil not included wireless charging for a good reason.
The parts how are needed for wireless charging need quite a bit of those conflict minimaals and wireless charging is energy inefficient what causes residual heat which can shorten the life of the battery.
Can someone conform?
For a (waterproof) case:
i remember @Meaghan dit post about a waterproof case,
i will add the link here if i found it:
added:
if you still like to have wireless charging maybe this is a option for you?
greetings
Tom
thanks thats so great
