tried, but no success. screen brightness is at max. still black screen, but generally responsive
Did you contact a #fairphoneangel? They might have a spare screen they could lend you for a test, or other spare parts.
Otherwise you might want to check for a topic in #participate:local to ckeck if there aren’t #localcommunities in your region. Or you could ask if someone couldn’t help you test a display.
At least you’d be fixed if the issue is with the display module.
Otherwise you might want to check if the aren’t any display offers in #market:offer that are cheaper.
And if not already done I’d advise you to backup your data as much as possible, your phone might die for good in a few days/weeks/months.
I have had an incident today where my phone got wet while I tried to save my dog who jumped in a frozen river and couldn’t come back ashore (true story).
Basically I did not think about my phone right away, and after coming back home and putting everything to dry, I realized that it had gotten wet and wouldn’t turn on anymore.
After drying it for some time, I tried to turn it on again but it still wouldn’t.
The behavior is odd and I’ve read some of it up here in this discussion: it’s vibrating as soon as the battery is put in, the charging light goes blue and the flashlight either flashes or stays constantly on if put on a charger.
I opened it up completely, there was still some water inside. I removed every module, made sure that every bit was dry and replace each module by a spare one. Same result unfortunately.
I will leave it overnight to dry longer, all major parts removed, but I am afraid that the motherboard is dead.
My big question is: if it’s completely dead, can I return it to retrieve the data at least? Some of it is on an SD card but some of it is in the phone memory.
Thank you,
Wanis
PS: the morality is “Save your dog or save the planet, you can’t save both”
(JK of course)
There is always a tendency to turn the phone on to see if it is working, but the battery can discharge through avenues it was not designed to and burn out some components.
- Phone’s should never be turned on once wet, they must be dismantled and dried it a good flow of air
- If the water was salty or dirty then the parts need flapping around in ideally distilled water to remove any salt or particles.
- Once ‘cleaned’ , if you think it necessary, and shaken dry and left in an air flow you can use isopropyl alcohol to draw out some water from accessible areas, like around the contacts
- As you will have voided any warranty you can also dismantle the modules somewhat for better cleaning
- It can take well over 24 hours to dry the innards of the modules
So before you buy any replacement parts you really have to dry it thoroughly.
There are many topics on the details:
Here’s some detail on the case where my daughter dropped it in the toilet, but a) it was for a brief moment and b) she took ages drying it before turning on.
The red square indicates water ingress
You can dismantle the modules, once you see a red square as the warranty is void.
Generally fo dismantling see
and some detail on the top and bottom modules
Cleaning all the contacts once wet and separated is a bit tedious see this about the contacts between the core module shield and the display
It can take a while to get any moisture from between the actual screen, glass etc.
Try and read up in the topics mentioned and search for more to give yourself an idea of what is possible.
If you still can’t get the phone to display see if you have a fairphoneangel near you that may assist.
Hi Amoun,
Thanks for your reply.
I did make the mistake of trying to turn it on before opening it thoroughly and drying it completely. I was in a “stress” situation as I am leaving to the countryside and I do need my phone to work for professional reasons (I have a second-hand phone just in case, but it’s old + the Android version is outdated + some modules are defective => so it’s important for me to have a functional Fairphone).
I am going to try everyhting but I can’t contact a Fairphone Angel, as I live in Iceland. Maybe I could become one over here someday, if a community grows ![]()
However, I am afraid that the motherboard (or microprocessor - whichever name fits better) is defective. So my main question is: is it possible to retrieve the data if the phone firmware/operating system itself is dead?
I would just like to be one step ahead and know my options in this potential case… Should I start looking into buying a new phone, send this one for repair, etc.
I have all the spare parts here. It’s no problem in that regard.
Thanks,
Wanis
No easy and cheap way to retrieve data, let’s hope once dried and cleaned etc. after a couple of days it works. Hopefully you had an SD card formatted as Portable that you stored things like images, unless you use a ‘cloud’
OK thank you Amoun.
So if I understand correctly, Fairphone would not be able to retrieve the data if I sent the phone back?
Could I still send it back to recycle some of the parts?
Thank you
Hi
Fairphone will not retrieve data or recycle parts.
The best in terms of recycling is to offer/send it to a #fairphoneangel
All the best
There are always professional services for recovering data.
But - according to what I have heard/read - they are quite expensive.
In Iceland I have found by a brief search Data Recovery Reykjavík, Iceland Service (Really no thorough search; so there might be more.)
I’ll keep my fingers crossed for you, but if drying the phone for a few days as described by @anon9989719 does not work, you could give this a try, if the data is really valuable for you. At least you might ask for an estimate regarding the possible costs.
Thank you guys
Fingers crossed, I have no touched it for about a week as I was travelling and it is all disassembled. We’ll see this week if it helped.
By the way, if it is dead, I would like to buy a secondhand FP3+ from a FPangel in BE. Would that be possible?
Which is the best forum/topic to ask for that?
Use the following category to place an add, and also direct it to an FPangel in BE if you think that may help, but there’s not much chance of an angel having one, but then you could be lucky.
