Yipppiiieee!!! mal and explit, you are great! Thanks a lot for your kind help!
Flashing the file
system.img
in addition brought the solution to me! Now I can boot into Fairphone Open without any problems! Iām very happy that I didnāt damage my mobilephone, because I thought that I could kill the ROM by flashing a faulty image of the systemā¦
Right now, I flashed the Sailfish-*.img-files and Sailfish is installing correct! Iām extremely relieved now, how can I thank you!
Okay, I did it all again for training-purposes⦠User mal is fully right: You only need the file
system.img
from the official Fairphone Open-OS to install Sailfish OS afterwards. I donāt understand why both manuals describe the other files boot.img and userdata.img also as necessary for the flashā¦
For all beginners like me: The fastest workaround to get Sailfish OS on Fairphone (via Fastboot) could be the following:
Install Fastboot on your computer (hint: Linux-Fastboot is even more comfortable! )
Boot your Fairphone 2 into the Fastboot-mode (push power-on-button and volume-down-button the same time)
Connect your Fairphone 2 to the computer by plugging the USB-cord
Check out that the program Fastboot correctly detects your Fairphone 2 (in Fastboot-mode) by entering the command
fastboot devices
A number should be displayed, followed by the word fastboot, e. g.:
a080d3f2 fastboot
Now you can start the flashing-progress. In first, delete all the remaining data on the phone by entering the command
fastboot -w
Next, install the file
system.img
from the official Fairphone Open-OS by using the command
fastboot flash system /directory_of_fairphone_os/system.msg
I was using the system.msg-file from the Fairphone Open-version 16.10 and did not
run into any problems.
Next, you can flash the two required Sailfish OS-files by the commands
fastboot flash userdata /directory_of_sailfish_os/userdata.img and
fastboot flash boot /directory_of_sailfish_os/boot.img
At least, you have to restart your phone and boot into Sailfish OS by the command
fastboot reboot
This worked completely fine for me! Until now, I didnāt recognize any problems when using Sailfish - weāll seeā¦
The wiki page https://wiki.merproject.org/wiki/Adaptations/libhybris/Install_SailfishOS_for_fp2#Installation_steps does not tell you to install boot.img and userdata.img from Android, those refer to files from Sailfish fastboot zip. The whole installation instruction assumes that you have Fairphone Open Source Android installed, it only mentions which version is recommended and doesnāt give instructions how to install the Android base image because those instructions are already available on Fairphone website. However in the Sailfish OS OTA update instructions on that wiki page the instructions for updating the base Android system.img are given in case that is needed.
Yes mal-, i only want to point out, if Sailfish is alredy installed on top of Fairphone Open, Fairphone Open could be updated easily to the newer Version,
when the user donāt flash the images
Of course your manual is the first thing which a person should read, before installing Sailfish OS on the Fairphone.
Thank you again for your work on porting and for helping others here on the forum!
You are completely right - that was a big mistake from my side! I thought it is the same thing like the described progress for installing Sailfish OS⦠Iām very happy about this great work of the developers! Thank you very much!
One other question:
Do you also lose nearly all of your installed applications if you switch of the developers mode? Furthermore, I canāt find the system-settings anymore after disabling the developers mode. Is that a bug?
There has been some issues with disabling developer mode in Sailfish OS community ports and a general rule has been not to disable developer mode. Itās sometimes problematic to get it back. It should be possible to manually install it back via telnet (ip: 192.168.2.15, port: 2323) using the command zypper in jolla-developer-mode. However I just tested and I could disable and re-enable developer mode from settings on my FP2 with 2.0.4.14 Sailfish OS. I believe it should work if Jolla account is set.
mal, thank you very much for your great help! Why do you know all those things? It seems that you are working for the community?
Iām still using the common Sailfish OS 2.0.1.11 alpha2 together with an Jolla account. Probably that bug was not yet fixed in this version⦠No worries, I easily reinstalled Sailfish and everything is fine now.
Let me anwer for Mal-!
Mal- is not only working for the community, he is a main SailfishOS on the Fairphone 2 Porter. Without his work we wouldnāt see any running SailfishOS Builds on the FP2.
It is very complicated to do all the work alone, but Mal- still do it. He is a SuperDev in my eyes!
Wow, I already expected something like thatā¦
I want to donate a little money to him because of his great work and his kind support inside the forum! Maybe we can crowdfund a little bit? Just to say thank you, because such an amount of work of course is not self-evidentā¦
There are many people who want support Mal- with a donation (including me)
As far i know Mal- donāt use PayPal (maybe it will change in the future)
Well, iām not familiar with other donation tools like Flattr or something elseā¦
I asked Mal- many times how the community could help / donate / support him.
But i didnāt got an answer
I also think its a huge amount of work. iām very happy that Mal- is such enthusiastical and and perfectionist person.
Lets hope his enthusiasmus will last for a while!
Hi all,
I also tried to install Sailfish OS 2.0.1.11 alpha 2 on my new Fairphone 2 using fastboot.
I am stuck at: fastboot flash userdata userdata.img
I get the error: FAILED (remote: Bogus size sparse and chunk header)
finished. total time: 27.525s
When I first started my phone I updated to Fairphone OS 1.8.1 using the updater app. Then I installed Fairphone Open 16.10.0 using the updater app ass well. This all went fine without any problem and the phone also worked nicely with the opensource OS.
I put my phone in fastboot mode and tried to install Sailfish OS 20.01.11-alpha2 following the steps described in https://wiki.merproject.org/wiki/Adaptations/libhybris/Install_SailfishOS_for_fp2#Installation_steps
My phone was recognized by fastboot, but at fastboot flash userdata userdata.img I got the error.
Now I reinstalled Fairphone open again, but this time using fastboot. No problem.
When installing Sailfish again I got the same error.
Then I went back to the normal Fairphone OS 1.8.1 and tried the procedure described by @Bobbel. Still the same error. There seems to be a problem flashing userdata.img because other files can be flashed without a problem.
I already searched the forum for a solution, but unfortunately I could not figure it out.
Does anyone have any idea what I am doing wrong?
I am using fastboot on a Mac.
Why are you using the fastboot method when you could install Sailfish from TWRP recovery using the other zip file mentioned in the wiki? I have also noticed that the fastboot method sometimes fails, not sure if it happens when you have too new Android installed on the device, I need to investigate what is causing that. I consider the recovery installation as the preferred method.
I had the same issue with the fastboot install route when I tried this for the EFCT16 Software workshop. In that case I first downgraded from 1.5.1 to Open 16.06 (which is listed on the wiki as having been tested). So itās not directly related to the version, though it could be that something was changed when 1.5.1. was installed that is not undone by flashing Open 16.06.
Thanks for the replies!
Actually the reason I used the fastboot method was that I didnāt know what TWRP was and how to use it. The fastboot method seemed quite straight foreward. I will try the TWRP method.
Could it be that adb/fastboot is generally (somewhat) unreliable on FP2? The dev of the magic-device-tool mentions this in the comments-section of this video about the tool: https://www.youtube.com/watch?v=lhKLfmBWE9w
and this lack of reliability seems to be the main reason, why the UBports community port of Ubuntu Touch for FP2 does not work properly atm⦠(?)
I donāt recall encountering any other issues with adb/fastboot when I was playing around with it on the community Fairphone, it was just the Sailfish image which failed twice. Then again, I didnāt do that much adb/fastboot stuff, so I canāt rule out random failure either.
