Using Different Modes for different Ring/Alarm volumes in different places
I’m trying to use the Android “modes” functionality. From what I read, I should be able to set up alternatives to “do not disturb” with different notification profiles.
My actual use case is that at home I need loud rings, audio notifications, and especially notifications from my doorbell; but when working in the office I need quiet rings and vibration notifications. I had hoped there would be a feature to let me set up a different profile for work and switch to it. I thought that Android Modes would let me do that.
The Moments app allows me to reduce notifications, but not allow some at lower volume. Do Not Disturb is similarly too extreme.
Is there a hidden feature that lets me do this? Otherwise, what apps would you recommend that fit particularly well with FP6?
Thanks,
Ian
Maybe you have a look at the tasker app. It’ll cost you a small amount of money but is afaik able to change the settings you wish, depending on your location.
