Using a bluetooth headset/earbud mic to record audio/video
Has anyone found or know of a way when making audio or video recordings to use the microphones in a Bluetooth headset or set of earbuds?
On Android, Bluetooth headset mics are normally only reachable over the HFP/SCO link used for calls; A2DP is playback-only. Camera and recorder apps typically grab the built-in mic and never open that SCO link, so it usually isn’t a simple toggle. Worth trying: a recorder app that lets you pick “voice communication” as the audio source, since that can trigger SCO routing — if it works, record audio separately and mux it with the video afterwards. Otherwise a USB-C mic, or a Bluetooth receiver with a mic input, tends to be more dependable. Curious whether anyone has got SCO capture working on the FP.
Thank you for the information and the suggestion,
