Hello everyone,
for more than 2 years now, I struggle to find a working USB-Adapter for LAN-Internet on my FP3 and FP4.
There a quite a few threads here in the Forum, but some of them are closed and there are also new USB-Adaptors on the market. Since I finally found a solution for all my needs. I want to share that with you. Maybe I can help some of you and save you some time.
Last year with the help of the posts here in the forum I found a USB-A Ethernet Adaptor that worked for both of my FPs ( i-tec U3METALGLAN ), but for using it on the FPs I had to use a USB-A to USB-C Adaptor in front of it. After a short time i had problemes with network interruptions. I bought new USB-A to USB-C adapters, but quickly the problems came back, I also had to unplug the adaptor and plug in again very often to reconnect the internet. That was frustrating and on top of it the bulky USB-A to C Adapter was annoying.
I decided to buy a new Ethernet-Adapter this time with build in USB-C
I tested some Adaptors and here is what I found out about the USB-C Ethernet-Adaptors:
| Adapter | ChipSet | FP3 | FP4 | iPad (2020) |
| HP USB-C to RJ45 Adapter G2 | ? | no | no | yes |
| StarTech USB 3.2 Gen 1 | RTL8153 | yes | no | yes |
| DELOCK Gigabit LAN 61026 | Realtek RTL8153B, VIA VL102 | no | yes | yes |
| DELOCK Gigabit LAN 62642 | ASIX AX88179 | yes | yes | no |
| DELOCK Gigabit LAN 65904 | Realtek RTL8153 | yes | yes | yes |
Cheers
Liquid
