Only charging works - when attempting to switch it fails.
Welcome! Can you elaborate on what exactly fails and how? Did you try different cables, USB-ports? What OS does the host-system have? Windows? Ect.
Directly to pc, ubuntu linux.
Same problem here since months…no system update solved the problem.
Even the Tethering USB is not working…it’s like the USB port is sleeping.
I tried a lot of different cables…nothing changed
Tethering USB was actually one feature i required so i tried /e/OS a long time on an old device to make sure it worked as required - must say i was quite dissapointed to find out tethering not working on FP5 at all. Now with this, well as a Linux admin i always find workarounds but got lazy over the years and just want things to work. ![]()
What do you attempt to switch and what do you want to do? It looks as if you didnt use a data cable.
Did you ever report to support? Else I’'m not sure how it should be fixed, although I’m not sure its fixable by an update as no common issue.
I tried disassembling the phone, I cleaned very well and with cleaner specific for electronic circuits and now it works! At least I didn’t try Tethering USB but at least my Fedora is able to list the FP5 in the File Manager
Tomorrow my new USB port should arrive, I start thinking that the problem is mechanical in the plug
[102650.390401] usb 2-2: Manufacturer: Fairphone
[102650.390405] usb 2-2: SerialNumber: 1897e711
[102650.402695] rndis_host 2-2:1.0 usb0: register ‘rndis_host’ at usb-0000:00:14.0-2, RNDIS device, 1a:63:c2:c0:8d:bb
[102650.423295] rndis_host 2-2:1.0 enx1a63c2c08dbb: renamed from usb0
[103232.497571] nfs: server 192.168.1.103 not responding, timed out
[103293.937843] nfs: server 192.168.1.103 not responding, still trying
[103326.706350] nfs: server 192.168.1.103 not responding, still trying
[103326.723200] nfs: server 192.168.1.103 OK
[103326.723202] nfs: server 192.168.1.103 OK
[103515.842859] usb 2-2: USB disconnect, device number 25
[103515.843166] rndis_host 2-2:1.0 enx1a63c2c08dbb: unregister ‘rndis_host’ usb-0000:00:14.0-2, RNDIS device
[103516.333111] usb 2-2: new high-speed USB device number 26 using xhci_hcd
[103516.463025] usb 2-2: New USB device found, idVendor=18d1, idProduct=4ee1, bcdDevice= 5.04
[103516.463033] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[103516.463036] usb 2-2: Product: FP5
[103516.463038] usb 2-2: Manufacturer: Fairphone
[103516.463040] usb 2-2: SerialNumber: 1897e711
PEBCAK, worked with the third cable, not sure what has happened between when i first got the phone in July and now but all OK!! Yey i have a new functioning device now, thank you!! Ticket closed. Have an amazing Christmas holidays.
