Terrible behavior! The Auto brightness feature is totally unusable this way. Why are things messed up with updates? I hate buying problems with others being solved. Can I downgrade?
Hi Yes you can downgrade but itās not automatic, you have to install an older version manually.
The downloads are available via
Ok the good news is that this morning the auto brightness seems fine.
I can cover the ambient light sensor and the screen is very usable, darkish as I would expect but would be good for the night.
Maybe the phone does have a brain or it just mine getting to see the light.
OK
I am interested in what your phone does after a restart ⦠Are the set values āāsaved?
I havenāt restarted my phone for days, since I wanted to mess with formatting SD cards and had to remove the battery.
As things seem to be improving Iāll see if in another few days all has stabilised and then Iāll do a restart and update here.
I think sometimes itās better to face the truthā¦
cu
The problem with the truth is that it is relative to the enquirer. It is true for some that it is now daytime, for some it is night, for some twilight and for someone off planet they can see that each is true and false and not something they can decide or experience and hence know.
OK There is an official response to the issue that it is being looked into.
I have started getting this in daylight and artificial light. Most annoying. I will try turning it off and see what happens.
Turning off the Auto brightness does avoid the problem, but is is being officially looked at.
However after 5 days mine has been stable for since yesterday evening. So hopefully there is some algorithm that I have managed to force into a useable function.
I should wary of speaking too soon, roll on the evening when the light dims.
I donāt know what thatās supposed to do?
Iām waiting for a official fix ā¦
unfortunately that doesnāt fix the problem for me.
Steven
Nice!
Then we have to wait and see first.
Steven
Maybe solved in LineageOS 18.1, but it is just a guess:
https://review.lineageos.org/c/LineageOS/android_frameworks_base/+/309848/
I have the same issue, and I only have it since the last update.
All workarounds I read here, are working for a day at the most on my Fairphone. The next day it re-appears at some moment. Especially, switching auto brightness off doesnāt help because my phone now adjusts its brightness even when I switch auto brightness off.
Itās annoying because it prefers to happen in dark on the go when I quickly want to look something up or call someone. Having to go to the settings and to find the brightness slider in the dark in order to see something at all, is a bummer.
I really hope they roll back this āimprovementā as soon as possible.
The brightness is two fold.
The sensor takes a reading of the incident or refracted light and this is used by the Auto Brightness algorithm to decide how bright the screen should be.
There seems to be a problem with the interaction.
a) The ambient light sensor has been reading
b) The Auto brightness setting is over-riden somehow
Hi welcome to the forum
Yes thatās the most difficult part
Yes, thats my favorite.
Just had to do that again, so much for my previous optimism that I was it beginning to work
Update: 4 hours later and is back to black
Thank you! I just applied you trick and it seems to work.
And now to something completely different. I tested you trick at 10:00 am. That gives me enough light to see every corner of my room. The Sensor reads 0. IMHO Fairphone needs better sensors.
