Hi Chrmhoffmann
Is it possible to upload only update files in the ROM instead of complete ROM file of 243.4 MB. Also, if it is possible, please show complete method who to add these filed in the ROM via windows PC / Laptops. Thanks for your hard work
One issue i found is "when adding a new contact to the sim card it says âunfortunately contacts stopped workingâ i checked it in all version i.e. 0.3 to 0.9.1 but did not resolve. Any idea, is this ROM problem or otherwise. Chris⌠Also while adding the contact into phone, it works fine.
Thank you! Just for making things easier for the lazy people (like me) I copied a part of the Changelog here. Check out the related xda thread anyway!
Changelog fp1-kk444-CH-0.9.2:
*- Fix that you can now call funny numbers like 143# without phone application crash - Fix to be able to add contacts to SIM card
(Update: snipped ⌠to show only the lastet change, for more check the xda site and chrmhoffmannâs comments)
BTW: itâs a bit misleading in my changelog. Gapps are not included. It basically meant: hey, there are new gapps out, why not updating them, too, at the same time you flash.
Thanks for your reply, but those answers make me feel less comfortable even. Itâs common that some antivirus find some risks that others do not, but there should be a reason for that. Also, other ROMs having the same issue does not make a difference about my concern.
Iâm aware that this could be a false positive, and that this could be most probably related to Mediatek itself, not the custom ROM. But I would like to be sure of it before installing anything.
Hello Mensha,
I searched the internet and found some info about this âvirusâ, I guess itâs related to these two files in /system/app/ : SmsReg.apk and SmsReg.odex. I deleted these files after installation (with a root-explorer like âX-ploreâ or âMiXplorerâ) and got no problems anymore.
See http://androidforums.com/threads/what-is-this.834392/ : "What is SMSreg.apk?
There are two interpretations of the
destination of this application. The first and most popular - a
malicious program that is specifically integrated into the firmware for
the pumping of money the user via SMS messages to premium rate numbers.
The second interpretation SMSreg.apk
has a practical application. According to her this application contrary
indispensable assistant and guardian. It allows you to send an SMS
message when a new SIM card. That is, in the case of lost or stolen
phone, you should receive an SMS with the IMEI number once the
new âownerâ insert your sim card
How to remove SMSreg.apk?
The application is hidden from the eyes of the average user, you will not find it in the list of installed programs.For what would be daring in Android SMSreg need to get root rights and set RootExplorer.Then in RootExplorer proceed to the file system / system / app and re-mount it with the right R / W.In the application you will see SMSreg.apk and SMSreg.odex.After removal of the program need to remount the file system again as R / O and reboot your smartphone.Now you can sleep peacefully - mysterious disappearance of funds from the account must stop."
By the way, these two files are present in every original fairphone-rom, so just delete them and enjoy the fantastic work of chrmhoffmann.
Happy flashing!
Thanks a lot for this information, really appreciated! The how-to-remove guide is very helpful too, Iâve never done such a thing but Iâll try. Do you know if thatâs possible to remove the files from the rom itself at any previous point?
I will also check if I can find the files in my FP1 rom (1.8.7), and maybe contact support to check if they are aware of the situation.
I removed these two files from the rom itself before installation, no problem. Under Windows 7 double-click on the zip-file, go to /system/app and delete these files and close the rom-zip.
