@chrmhoffmann: I find it really awesome that you are taking your time to show us a possible future for updated Android on the FP1!
Some months ago it seemed a very sad and dying topic, but now I am highly encoured to follow your progress (even without having the possibility to help)!! Keep on - I (we) like it!! Cheers, Robert
P.S.: Does it mean you bought a FP1 or got one from FP to test your builds?
But it was no official āsponsoringā from FP (which I would highly appreciate)?
And in one sentence, how you would now rate the future-proofness of the FP1 after your recent succes to port 4.4.2.? Are you optimistic (from the software-point of view)?
Yes, it was somehow official sponsoring. They sent me an FP1U unit - after my own one broke down.
I have troubles fixing the remaining instabilities. But I have some hopeā¦ After 4.4.x it will be really difficult as there is definitly no MTK support at all for this chipset AFAIK.
I just want to share the current Android History Plot from Wikipedia, to which I added the FP1+FP2 release dates (approx.)
Without any comments from my side for the moment ā¦
Cheers, Robert
On 4.4.4-0.5 I confirm all the previous @ralf_xda 4 issues.
I also add Xposed framework gives me a compatibility alert so I didnāt install it yet (on 4.4.2 it worked quite well).
Iāll try 0.7 ASAP
Thank you very much @chrmhoffmann for your great work!
Didnāt flash yet, but it seems the problem with the screen timeout and sometimes with the status bar not expanding to see the notifications is linked with the missing lock screen.
I didnāt understand yet why the lock screen ceases to appear (I use only sliding for unlocking but I tried also with pattern), but when I turn on the phone and it doesnāt appear it seems the screen timeout is the same as if it was still on the lock screen (few seconds); then, after this using the device a bit (browsing the web or reading the email), the timeout restores at the one configured (as if the screen was āunlockedā).
I canāt provide logcats nor a reproducible use case, but I want to try 0.7 before further investigations
Thank you very much, bye!
I am on v7 and the only issue so far is the camera, it only shows 6,2 Mp max. Lockscreen timeout seems fixed. Xposed is ok with the zip-file by Quallenauge.
Great work!!! Thanks a lot
Joachim
@chrmhoffmann: it seems the lock screen issue is fixed! and as I supposed even the screen off timeout issue disappeared, so I think they were linked together
Thank you very much!
The default camera app is a bit misleading. For some reason, the MTK guys have used āPreview sizeā (also in other translations) for something called pref_camera_picturesize_ratio_title that defines the picture ratio (16:3, 4:3).
This means you have to go to the camera settings->Preview Size and change it to āStandard (4:3)ā and then you can see the 8MP in the āPicture sizeā menu.
I used the version 2.6.1 (de.robv.android.xposed.installer_v32_de4f0d.apk ). Then rebooted into recovery , wiped cache and dalvik-cache, then installed the latest zip from Quallenauge.
Maybe itās important that I first installed the version 05 from chrmhoffmann, then open-gapps-arm-4.4-nano-20151118.zip, booted, installed de.robv.android.xposed.installer_v32_de4f0d.apk, rebooted into recovery and then flashed the latest zip from Quallenauge.
Then I booted into recovery, wiped cache and dalvik-cache, installed version 08, then then open-gapps-arm-4.4-nano-20151118.zip again, then the zip from Quallenauge.
I do not really know but everything works now this way. I guess you have to try outā¦
Good luckā¦
