I cannot answer incoming calls from my new Fairphone 3+.
When someone calls me tapping on the green button I see the call starting but I don’t hear anything. Whoever calls me, on the other hand, sees no answer, as if I do not answer the call.
Hi and welcome to the community. This could be related to the SIM card, so probably faster then contacting Fairphone support is contacting SIM provider to receive a replacement SIM card.
Thanks for your answer!
My Fp3 + arrived yesterday … And this morning I received the first call. So … it never worked.
The software is Android 10, patch of August 5, 2021.
SIM cards might be faulty and not working properly even if working properly in other phones. I had similar issues when I switched from IPhone to FP2, all my calls were directly routed to the mailbox and did not even could see missed calls (not sure of the call popped up and I could have taken it, as you describe or if I just missed that) but was able to call back the people. I for sure thought it’s a FP bug as SIM worked in the IPhone and was quite surprised when FP support asked me to contact SIM provider and describe the issue. I received a new SIM and that solved it
The issue @DeepSea was initially effering to, would not affect FP2 but only FP3(+). However, at least so far only affecting Germany, so if your SIM is not a German one you should not be affected by this. The FP2 does not offer VoLTE.
Welcome! I’m in Italy and have WindTre as well.
I upgraded my FP3 phone to the August update.
I can answer calls.
I sporadically had call issues (outgoing calls not starting, incoming calls dropping on answering), but my guess was that the nw was not OK or my phone was hanging.
Are you reusing the SIM from previous phone or is it new?
Maybe there are some NW setting to be checked.
