Ultra-low brightness
When I first got my FP5 running Fairphone OS, the ultra-low brightness feature was quite effective – it really did reduce the brightness in a dark room. However, since an update, it hardly reduces the brightness at all, even though I’ve set it to the minimum level. Unfortunately, I can’t remember whether this happened following an update before I switched to /e/OS or whether it came later with the 4.0 update. It was really handy as it was more effective than any app you could install for that purpose.
Does anyone know anything about this?
I suggest to rather check the e/OS forum
I posted on their French-language forum (in July) but didn’t get any replies. I’ve posted here because I’m no longer sure whether this feature has become less reliable following a Fairphone update or after I switched to /e/os. I was planning to post my message on their English-language forum, though.
As an alternative, I use Twilight from Google Play. If you turn down the light of your FP5 to minimum, this can take it so low that in a normal light setting it looks almost black, but in a dark room you can barely see. It is primarily a red filter, although these settings are independent from each other. I have used it since my first smartphone which was 3 or phones ago now.
However. I highly recommend doing a bit of research yourself, just to verify that I don’t feed you false information. Link is provided, bu you can also search for Twilight and see a red circle with a white halfcircle in the upper part of the red circle. Like a twilight sun hanging on the horizon.
And yes, It is related to your question, but not the answer for your query. https://play.google.com/store/apps/details?id=com.urbandroid.lux
Same here with my FP6+ and eOS ! It’s still really bright at low light… hard to watch the screen when you’re waking up :slight_smile:
