How? It doesnât seem to work. The IMG canât be fastboot booted, and the ZIP seems corrupt or is not for unzipping?
Doesnât work, still freezes at âFairphoneâ.
And it gives the notorius âYour device is corruptâ routine, at least I didnât have this before attempting to install A.0110 this way.
It seems I went straight for the update problem âŚ
I came from a stock A.0105 with an unlocked bootloader.
Installed twrp-3.3.1-0_k4y0z-20200124-02-fp3.img, which worked fine.
Installed Magisk, which worked fine, too.
Along came A.0110 ⌠and wouldnât install, the updater always gives âInstallation problemâ.
I tried to restore the TWRP backup I made before I changed anything.
I tried to flash and TWRP-install the stock A.0105 packages given here in the forum.
But it doesnât help, this way I apparently donât get back to a stock A.0105 which can update itself.
Before trying the GSI stuff, I at least wanted to get the ârealâ stock state back.
So ⌠logcat âŚ
02-01 01:41:13.137 733 733 I update_engine: [0201/014113.137048:INFO:delta_performer.cc(386)] Applying 25 operations to partition "dsp"
02-01 01:41:13.140 733 733 E update_engine: [0201/014113.140342:ERROR:delta_performer.cc(990)] The hash of the source data on disk for this operation doesn't match the expected value. This could mean that the delta update payload was targeted for another version, or that the source partition was modified after it was installed, for example, by mounting a filesystem.
02-01 01:41:13.140 733 733 E update_engine: [0201/014113.140504:ERROR:delta_performer.cc(995)] Expected: sha256|hex = 2CF4CC1F349D4F27622AFD18DCFFBF5524A7BE034A2CDEEA5C37B043C8C7D10B
02-01 01:41:13.140 733 733 E update_engine: [0201/014113.140548:ERROR:delta_performer.cc(998)] Calculated: sha256|hex = BA89F38FC449A7DE9C3A9BB210F2F65C3C8A0A17D2AD83BB391F09DCD838AB5F
02-01 01:41:13.140 733 733 E update_engine: [0201/014113.140590:ERROR:delta_performer.cc(1009)] Operation source (offset:size) in blocks: 0:2
02-01 01:41:13.140 733 733 W update_engine: [0201/014113.140677:WARNING:mount_history.cc(66)] Device was remounted R/W 2 times. Last remount happened on 1970-01-01 00:00:49.000 UTC.
02-01 01:41:13.140 733 733 E update_engine: [0201/014113.140734:ERROR:delta_performer.cc(1038)] ValidateSourceHash(source_hash, operation, source_fd_, error) failed.
02-01 01:41:13.140 733 733 E update_engine: [0201/014113.140780:ERROR:delta_performer.cc(298)] Failed to perform SOURCE_COPY operation 1385, which is the operation 0 in partition "dsp"
02-01 01:41:13.140 733 733 E update_engine: [0201/014113.140823:ERROR:download_action.cc(337)] Error ErrorCode::kDownloadStateInitializationError (20) in DeltaPerformer's Write method when processing the received payload -- Terminating processing
For a start thereâs something wrong with the dsp partition.
Can something be done about this?
I have previously uploaded the img with the wrong file extension.
the zip is actually an img.
I have since uploaded it with correct filename.
Please make sure to install using the current version of TWRP.
The problem with the dsp-partition is known, and I have uploaded a new version of the 105 ZIP that includes the correct dsp partition.
It is linked at the top of this thread.
I have the same problem like AnotherElk. Now I can still boot into fastboot, but from there I cannot fastboot flash system {gsi_image}, I always get the âYour system is corruptâ-error.
So I would probably need a stock image that I can flash via fastboot and not the TWRP installable stock that is provided here. Where can I find that?
Which firmware did you install?
Did you use the TWRP build from today?
Can you still fastboot boot TWRP?
Can you not confirm the corruption message?
Did you try to factory-reset using stock recovery?
I tried to install the A.0110 firmware via TWRP with the TWRP build from today.
I cannot fastboot boot TWRP.
When I get the corruption message and do no nothing, the phone just switches off after 30 seconds.
When I try to boot into the stock recovery I also get the corruption message.
When the corruption message comes up, you need to press the power button, so it doesnât shut down.
if you cannot fastboot boot TWRP you probably need to set the current slot active using fastboot to reset the retry-counts:
Setting active both slot didnât work either and I also cannot boot into the old twrp. I donât get any specific error, I only always end up in the âYour device is corruptâ-message.
Thanks, the new TWRP works.
My failed try was with the IMG file already, but I think fastboot boot didnât work momentarily (saw this mentioned here now, too).
âOOPS! no mirrors found.â ⌠@Martin_Mattausch-Wiementioned this, too. Is this a temporary thing with Android File Host? The file has 0 downloads so far. Hmmm âŚ
I formatted data and wiped system and tried again, same result.
@k4y0z: Is there an A.0110 dump available for fastboot?
Iâm really having trouble now getting back to a booting A.0105.
I got this working yesterday, even if not straightforward.
I had to randomly throw fastboot flashing the A.0105 partition dump, TWRP-installing the A.0105 ZIP file, recovering my A.0105 backup and factory resetting from the stock recovery at the phone, and somehow a combination of this worked in the end.
There was no reproducible, clear path for me to get back, because nothing of this all worked on the first try.
Today ⌠no such luck.
As it stands âŚ
I unlocked the bootloader ⌠got a boot message, no big deal.
I used TWRP from January 24 ⌠this apparently breaks OTA updates.
Not nice, but no big deal, Iâm an early adopter, this should somehow work out over time.
I installed Magisk and rooted, and uninstalled Magisk again ⌠which works like intended, but I take it this doesnât help matters when I want to revert back to clean stock somewhen.
I tried to TWRP January 24-install the A.0110 ZIP ⌠got the additional âYour device is corruptâ message.
Kind of annoying, but ok, just one more press of a button when booting. I somehow got back to A.0105.
I used TWRP from January 31 ⌠which didnât result in a booting A.0110, too, and now everything I try to get back to A.0105 fails.
(Which could be coincidence and not the new TWRPâs fault, but I donât know how to determine that.)
Iâm stuck, and a little worried by now because I seem to descent into unworkable step by step.
I could use a reproducible, fail-safe way to install any version of the stock OS.
To get rid of the corrupt message you can do this :
But probably, before that, youâll have to flash back to the A.0105 stock ROM.
In order to do so, you should download the full stock dump here and follow the instructions to flash it here. Do not forget to flash both slots and to:
If you are working in a shell environment (*nix or Windows) you can run all the instructions as a bash script like this (donât forget to change the active slot when necessary: current is âaâ):
Not sure whatâs up with that, I tried yesterday and it showed me mirrors.
Iâll see if I can reupload the file.
Did you try booting the stock recovery and doing a factory reset from there?
Iâll recheck the file, though I am sure I uploaded the correct version
You can use the full-stock dump to revert back to 105 stock using fastboot.
You will have to replace the dsp.img with the one @corvuscorax uploaded here:
@corvuscorax Could you maybe do me the favor and double check the 110 file, that all the partitions it contains are indeed correct?
Works fine with copy and paste (with a sanitizing copy and paste detour via Notepad ). I checked that every command was executed, and without error messages.
I did exactly that.
Thanks for pointing to that post, I had downloaded the dsp.img, but I somehow didnât find the post again where it was from, so I feared it got retracted and I shouldnât use it .
Good question. Iâll retry. Edit: Same result, still freezes at âFairphoneâ.
Thanks for these two posts already, all these files and instructions spreaded over various topics, I always think I missed something ⌠I feel a bit better now .
Does that matter?
It still doesnât boot, when I try it boots into stock recovery and says âCanât load Android system. Your data may be corruptedâ.
These errors are fine, you need to flash the dsp.img uploaded by @corvuscorax if you want to be able to OTA afterwards.
If it offers factory-reset, do it.
About the 110 ZIP linked above.
I think I have found what was causing the issue.
I have used the truncated files instead of the zero-padded files in the ZIP.
This may have resulted in the checksums not matching.
Iâll reupload the file with the full partitions
