Hello friends!
I’m currently doing some tests with linux-based alternatives OS on my FP4, Ubuntu Touch and Sailfish OS.
I wanted to try TWRP backup and restore, and share here my experience ![]()
NOTE: those two OS are not encrypted so it’s ok for me.
On my FP2 I have a long and successful story of using TWRP to switch between alternative OSes.
It consists of backup and restore of 3 partitions : Boot/System/Data
Here on FP4 partitions are slightly different (A/B device), I found here that one can do:
- Data Backup: select only the Data partition.
- System Backup: select partitions
- Boot
- DTBO
- Super which contains the logical system, system_ext, odm, product, and vendor partitions
I tried with Ubuntu Touch, however I have those red error message:
failed to mount '/system_ext' (Block device required)
failed to mount '/product' (Block device required)
and I’m only able to backup Data
NOTE that this could be already useful, in this case the restore process is:
- Erase the previous OS
- Fresh install of UT
- TWRP restore of /Data partition, and reboot
I then tried with SailfishOS and, even if there is no red messages, backing up of Super partition failed at 67% (4215Mo of 6264Mo).
Looking at the recovery.log, there is this error message:
Backing up Super (system system_ext product vendor)...
I:Reading '/dev/block/by-name/super', writing '/external_sd/TWRP/BACKUPS/xxx super.emmc.win'
I:Error writing destination fd (Operation not permitted)
Backup Failed. Cleaning Backup Folder.
Searching for a solution, I found here that this could be due to a FAT32 SD Card (and indeed my SD card is formatted in FAT32 filesystem)
I tried again on Internal Storage.. and it worked ![]()
[BACKUP COMPLETED IN 80 SECONDS]
I have now a full backup of SailfishOS 4.5.0.24.
In the backup folder (total size 7.73 Go), the file super.emmc.win is 6.00 Go big!
Could you try again? it could be the same issue ![]()
