TWRP detects no files on external SD Card
I’m referencing to the following solved topic:
https://forum.fairphone.com/t/stuck-optimizing-apps-after-updating-on-fp-open-os-16-07-1/21146
I have the same problem after updating to Fairphone Open OS 16.10.0 and the mentioned solution does not work for me.
I can’t find any files on the external SD Card in TWRP mode and therefore can’t reinstall the update.
Thanks for your help.
ChrisR
Any chance using adb sideload in twrp?
To use adb sideload, i installed ‘Minimal ADB and Fastboot’ (http://forum.xda-developers.com/showthread.php?t=2317790) on my Windows 10 computer, which worked fine.
Now i could transfer files to my FP2, but i think i misunderstood the mentioned solution
https://forum.fairphone.com/t/stuck-optimizing-apps-after-updating-on-fp-open-os-16-07-1/21146/2?u=chrisr
I thought that i should reinstall the Fairphone Update via TWRP (which did not solve the problem) but instead of that i had to reinstall the Gapps via TWRP.
Now everything works again.
