Two separate issues after latest couple of updates - Touchscreen and navigation buttons
My touchscreen sometimes stops working randomly. The home button still works and the issue resolves itself when I press it and then return to the program/app. It’s across different apps and not seemingly connected to any specific input. This started a couple of updates ago, but I don’t know exactly when or which update.
The last update which I installed today (2026-03-27) switched my navigation buttons around and I can’t switch them back. Others seem to be having this issue as well, but I don’t see any response or action from the FP developers? It shouldn’t be a big thing to patch.
The forum is no official contact to Fairphone so you cant expect a response here.
Edit: I will close here, because the screen issue is discussed here
And the other issue in the main update topic
And in this seperate topic
