This night my day-1 FP5 had annissue on the Power button, basically its broken. No big issue since I can lock/unlock the phone without the physical button.
My only problem at the moment Is: how ncan I turn on the phone without the physical button?
I never turn off the phone buy you know…maybe battery goes to 0% or for example I should change my main camera modulo.
Is there a way or walkaround?
While this was originally figured out for the Fairphone it works the same way for the FP5 (you might also want to see my own reply there a few posts further down).
