Trying to reflash Fairphone 4 with Fairphone OS 11, but scripts pause
Fairphone 4 currently with IodéOS installed. I want to reflash the phone to Fairphone OS 11 and possibly flash either Ubports or /e/OS on the phone. I have adb and fastboot installed on a Q4OS Linux install with runit as init system.
I have tried both the Fairphone 4 script, as well as the /e/OS script. The phone is detected by fastboot:
$ sudo fastboot devices
b96db9a6        fastboot
Unfortunately neither script gets any further than this:
$ sh ./flash_FP4_factory.sh
./flash_FP4_factory.sh: 22: Bad substitution
*** Fairphone 4 flashing script ***
INFO: The procedure will start soon. Please wait...
Note that this will detect and flash only on FP4 device.
INFO: You are using a Linux distribution.
INFO: Looking for connected device(s)...
Very weird. Not sure what is going on. Help?
Have been following this thread as well? Essentially the wrong USB cable was the culprit. It sounds a little bit like this is the case with you as well.
One of the worst experience is using low budget USB-cables. To avoid is, use only premium USB-data-cables. Otherwise you are struggling with various strange and mysterious problems.
A new day. Trying again and I get the following:
$ sh ./flash_fp4_factory.sh
INFO: The package type is "user-factory"
INFO: The build number is "FP4K"
INFO: Validating the integrity of the package.
      This might take a while. Please wait...
INFO: Validation complete.
-en
WARNING: Flashing this image wipes all user data and settings on the phone.
         It will also remove the Google factory reset protection.
         Are you sure you want to continue?
         Type "Yes" (case sensitive) and press enter to continue: Yes
-en
./flash_fp4_factory.sh: 102: [[: not found
-en
WARNING: No Fairphone 4 found in fastboot mode.
WARNING: Make sure that a Fairphone 4 is connected.
-en
I have tried two different cables. The first, is the same one that I used when I flashed the phone last time. It has just been sitting at home, not banging around in a bag, so I don’t see why it suddenly wouldn’t work…
What do you see, if you type
fastboot devices
in your terminal ? You enter fastboot with the device powered off, hold Volume Down + Power.
Edit:
I think, you are running the wrong shell. Which operation system you are running on ?
If you look into the script, you can see, that the shebang is looking for bash
#!/usr/bin/env bash
Try to start the script with
/bin/bash flash_FP4_factory.sh
or simply typing
if you shell is already bash. You can determine the shell in your environment by typing
echo $SHELL
$ ./flash_fp4_factory.sh
INFO: One Fairphone 4 in fastboot mode found (serial number: b96db9a6).
Yes, I am using bash shell. I have the phone set to the fastbootd menu. The script exited. On the phone, I get:
Now send the package you want to apply to the device with “adb sideload ”…
Install completed with status 3.
Installation aborted.
Interesting. So, I wasn’t able to flash Fairphone OS onto the phone for some reason, but the /e/OS version flashed directly over the IodéOS. What if I want to Install UBPorts instead?
You need fastboot not fastbootd
And for Ubuntu I think Android 11?
Not, if you call the script with a different interpreter like sh. On Debian, Ubuntu, … sh is linked to dash, which isn’t 100% compatible with scripts written for bash.
Using dash is the reason, why you get errors like
or
The boot menu on the phone is fastboot. I don’t know why there is a capital “d” at the end…
Both exist fastboot and fastbootd and when you see fastbootd on your phone you are in the wrong mode
Can you please explain the process to get to fastboot?
Make sure your Fairphone:
  • Is in fastboot mode
Isn’t much of an instruction…
My bootloader is of course already unlocked, as IodéOS is on the phone.
The Fairphone is an A/B-device and your are maybe in the wrong bootloader slot:
fastboot getvar current-slot
If you are in Slot ‘a’ simlpy type
fastboot --set-active=b
or
fastboot --set-active=a
if your active slot is ‘b’ and restart the bootloader.
I checked that already. I am in the correct slot, as far as I can tell.
Please note that I successfully flashed Murena /e/ over IodéOS, but not sure what was different. I am still interested in knowing how to get Fairphone OS Android 11 back on the phone so that I can flash UBports on it.
A. I am not sure, if it is already there (yet). One could tear appart the script flash_fp4_factory.sh and execute the fastboot flash commands manually in order to observe pure fastboot commands error handling.
B. Considering the workflow, it might be worth putting the 1. fairphone in fastboot mode. 2. Then detach cable. 3. Fire up the original script. And once it awaits for an available FP4, 4. reconnect the cable.
As the title states, the article is about managing the bootloader (if it is locked). My phone was already unlocked. There is nothing about how to make sure the phone is in fastboot mode, rather than fastbootd…
I just used the usual procedure on the phone with the volume down and power on buttons. From there, I navigated to fastboot(d).
You asked me how to boot into bootloader and its described in there
Adb reboot bootloader
Now I am confused. So when I start the phone with the volume down button pushed, I don’t arrive at fastboot when I chose recovery mode and then advanced?
Then your are in the correct mode!
