Transparent Cases!
It’s been a long time since i received an indigo case from Fairphone after the transparent case broke apart.
Tho i thought i could get familiar with this one it really seems i cannot think about any other case than the transparent one.
From time to time i go check the website to see if they have relaunched them but nothing happens so i wonder…are they completely gone?Or is there still some kind of development going in the background some of you know?Will we ever see them again?
Cheers
I believe the time where any new hardware is developed for the FP2 is over. The problem with the transparent cases (they crack) was never solved, so they are gone for good. There are some community projects in the #participate:diy category though.
Like this:
