Transferring data from old phone to fairphone 5 e/os
Hi, I seem to be not able to transfer data from my old phone to my Fairphone 5 E/os can anyone help. the tutorials are not helping
Have you looked at this? Migrate to /e/OS
What doesnt work and which tutorials are you referring to?
  1. To Copy apps & data, tap Next until you’re asked to find a cable.
    2.Tip:* This is usually the cable used for charging.
The above steps do not show on my fair phone so i am not able to transfer the data.
You can only do this after the first boot/setup. You need a factory reset to trigger it again, unless you are using a Google pixel…
I have reset to factory many times but it never pops up.
What do you mean by a google pixel??
It might be the wrong cable or does already before attaching a cable nothing pops-up? Can you step-by step add what screens show up and what do you select? A Google Pixel is a Phone from Google, so nothing for you to think about.
Where is this coming from?
Google own phone lineup
I have now reset the phone to factory setting.
This is wat pops up:
enterpin for sim
start
language
wifi
date and time
parental advisery
location services; both boxes ticked
navigate
install fingerprint
set pin code
synchronise murena account
and thats all
Well I guess as you use e/OS what you are looking for just dont exist?
according to the manual from fair Phone it should be this easy. just follow the steps…
Fairphone for e/OS? I doubt that. I think this is meant for Google certified phones and the e/OS documentation was linked above by @Furdiburd and it not mentioning this.
The problem probably is that on e OS, cable connections are by default restricted to charging. You can change this somewhere in the settings to data transfer and allowance to change from external device (= your computer)
