Hi, I just transferred from FP3 to FP6, made the transfer with a cable. I thought it would include everything on the SD card that I had in the FP3 as well, but turns out that it didn’t.
Does anyone know - if I just take the card from the old phone and put it in the new one, will things like downloaded podcasts (which I saved on the card) show up in the relevant app, or do I need to do something else to transfer the content from the card to the new phone?
OK, reading in the forum I see you are supposed to be able to have both. Fingers crossed it won’t get stuck or otherwise faulty, as I see it can have its issues…
I wouldn’t give up and reformat it just yet. Redo Backup And Recovery is my favourite tool that can be used on either disks or as a bootable disk for computer recovery. It works with both Windows or Linux machines. I didn’t unmount my SD card before removing it from my FP3.
