Switch from Murena e/OS to Android OS on Fairphone Gen6
Hello, I was given a Fairphone Gen6 with e/OS Murena. I’m completely lost and would like to switch to Android. The 14-day return period has, of course, passed. Is there a complete step-by-step tutorial with pictures?
I found this link, but it doesn’t work from step 3, point 7 onwards. There’s something I don’t understand.
https://support.fairphone.com/hc/en-us/articles/10492476238865-How-to-unlock-and-re-lock-the-bootloader
Thanks for your help
This is the only official guide and what exactly does not work? What PC System do you use?
And a Warning: check the security patch level of the e/OS Version you have installed and ensure the one from FPOS is newer!
What are your issues ?
If you don’t like the iOS looking of the default BlissLauncher, you can install any Launcher of your choice..
If the Apps Store is bugging, there workarounds..
Even degoogled, /e/ is an Android Operating System…
I understand you mean FPOS, that is the Fairphone OS version of the Google provided Android.
the issue is, for a not understandably reason FP doesnt call its system FPOS anymore but only Android… so I gave up to correct this, its wanted by FP, while we asked for an explanation in a closed group we never received one.
