New to Fairphone. How do I switch between apps? I can’t find a way to see all open apps. I can only start an app from new. Must be something easy I just don’t see.
Welcome to the Fairphone Community.
Which software are you using? Standard google based Android or /e/OS?
Are you working with navigation buttons or gestures? If the latter, just swipe the upwards starting at the horizontal line at the bottom of the screen. If you are not using gestures, use the square symbol at the right of the symbols at the bottom of the screen.
What phone or OS did you use before?
Hi Incanus,
I use standard android. Before I used Samsung Galaxy A50.
Swiping from the horizontal line works, thanks! Apparently I swipe mostly a little bit higher, which shows you all apps. Thanks a lot!
Yes, that’s the App drawer.
Did you use the three button navigation on your Samsung? If you want to use that again (I prefer the gestures) then you can switch that in the settings of you Fairphone,
Thanks, but I will get used to the gestures I suppose. Good to know you can change it in the settings. A lot to discover still.
