same here - thank you soo much for this nice little workaround
After my alarm woke me this morning, I suddenly can’t disable the “Do not disturb” setting om my phone, and can’t enable ringtones and such.
When I try to push the button, nothing happens, and it keeps to stay in “Do not disturb (only alarms)” setting.
I hope someone can help.
Reboot dosen’t help
Thanks alot, that helps!
I was stuck in “Alarms only” mode and the workaround worked for me.
Is this bug being solved for the next update?
Thanks.
Not for Android 6, apparently, but Android 7 is coming.
I had the same problem this morning and the workaround worked for me as well!
Best regards!
I just had the same problem, and found the workaround helpful. However, I hope there will be a more permanent fix.
I expect it to be fixed in Nougat, but we won´t know until it is available.
Hi there. I had the same problem. Doing that trick with the utomatic rules worked. And now it works fine. I erased the new rule and I switch it on the panel. Thank you!
Thank you Volker - I just had this bug but your workaround solved it very quickly and easily. Wonderful!!
Thank you so much! Easy solution:+1:t4:
