Starting up problems
Hi, This is my first fairphone. Got pre-installed murena os to avoid google. But the phone would not load any apps via App Lounge when i rejected google option. Saw in the forum that this is a common problem so did as suggested and did factory reset.
I am on my 3rd factory re-set. I am thinking of continuing with google sign in, but wonder what then was the point of paying extra for a de-googled phone?
I am not tech savvie, and would appreciate advice on how to opt out of google whilst still being able to access my old apps/data.
Also, the seal on the box was not intact when I opened the package. I didn’t want to return it just because of that because have been without a phone for over week now. But on the “about phone screen” the model is showing as Fairphone 6, not 6+. Have fairphone sent me the wrong phone? I understand the 6+ is meant to be less glitchy.
Any advice gratefully received. I will check computer in a few hours.
Thank you!
Hello and welcome to the community forum
I believe the phone was opened by a third party company who installed e/OS for you. If you wish, I can look for the relevant discussion in the forum on the evening.
FP6 and FP6+ differ mainly in the RAM amount and the processor, the software is the same. But I believe you can check the amount of RAM somewhere to make sure which one you got - there’s also a dedicated topic to that somewhere.
Are you unable to install any apps or just some? Are these google related apps? Did you have any paid subscriptions via PlayStore?
Thank you so much for your reply. If it is normal for the phone not to be sealed after installation of e/os then I’m ok with that. I started worrying that it was a returned phone that has some inherent problem.
I have checked the memory and it is 12GB + 256GB which I believe is the 6+ spec.
First two attempts at starting the phone: I opted out of using google services, but couldn’t download any apps from the App Lounge, eg it took 20 minutes to download whats app. When it was on 100% I tapped it and instead of opening, it offered the “install” option. It had never loaded. I tried loading Signal, but that never got past 34%. After almost an hour I cancelled that.
I don’t think I have any paid subscriptions on PlayStore. The screen broke on my old phone so I have no way of checking anything on that. I’m pretty sure I don’t pay for any apps.
On the third reboot I decided to link to google. Google tried to send me a verification text, but it never arrived and I got blocked by google for “a few hours”. I asked my friend o send me an SMS and it arrived fine, so don’t understand why google verification texts aren’t getting through.
I’m wondering if I’ve made a big mistake in trying to escape the google monopoly…I really don’t want to be a data source for google, but am getting concerned that I don’t have the brain capacity to make this work.
Please do send me in the right direction for further advice. I must have a working phone soon.
Thank you
:hugs:
Hello
I don’t use e/OS so will not be able to help you any further.
But I searched our forum for the issues with App Lounge and the solutions I managed to identify
  • check the e/os dedicated forums
  • give up and sign up with Google
  • use other app sources like F-droid/Aurora store
Hello @4riffs ,
I’ve been using Murena OS for more than 5 years and I’m sure you should be able to download the mentioned apps via App lounge without entering a Google account. So what you observe is at least not normal (although, als @Meaghan mentioned this app sometimes makes problems; but during the last months it has always worked fine for me).
There’s also no need to do a factory reset only to change settings of app lounge. If necessary you can just delete the data of the “app lounge” app.
My advice would be to check your internet speed (are you really connected to a good wifi or fast mobile data connection when trying to download and install the apps?) and to rather disable “hide IP address” in the “advanced privacy settings” (if that’s not already disabled anyway and as long as you’re not sure about the implications of this setting).
