since days I’m trying to set up a VPN connection but it always fails. From my laptop I can make a VPN connection so the configuration at home and at my dynamic DNS provider are ok so far.
My box at home gives the following information for Android devices (> 4.0.4).
Type: IPSec Xauth PSK
Server-Address: acrobic.no-ip.org
IPSec Identifier: vpn_user
IPSec Pre-Shared Key: w57gwJUIw89d1
Normally it seems to bee very easy to set up a VPN connection, so I’ve done the following:
System --> setup --> wireless --> more --> VPN --> (+) (= add VPN profile)
type: IPSec Xauth PSK
server address: acrobic.no-ip.org
IPSec-ID: vpn_user
preinstalled IPSec-key: w57gwJUIw89d1
[ save ]
Now I see the list of all available VPN connections. When I choose the created “VPN-conn” the it asked for a login name and password.
user name: vpn_user
password: <my_secret_pwd>
[X] save account information
Then the FP1 tries to connect but this seems to be failing. After less then one second later there is written “disconnected” (or similar) but without any reason. I’ve checked everything several times if it’s written correct but I always get no connection.
For comparison I use the following setup on my laptop (Linux Mint installed) where I can make successful a VPN connection.
Gateway: acrobic.no-ip.org
User name: vpn_user
(shown as dots)
group name: fly_away
group password: w57gwJUIw89d1
(shown as dots)
Is there anyone who knows what could be wrong? I’m confused, I 've absolutely no clue what’s wrong.
