I have some various issues happening in the same period of time :
Random half reboot (i find the phone just reboted ask me to my phone password but not my sim password
I can uninstall 80% of the app, no special error, just nothing happening no matter the way I ask the uninstallation (directly by moving the app or via the program list
When I try to move some files in the SD card (eMMC to SD) I have the following error : java.io.IOException: write failed: EIO (I/O error). If I just to a copy or a cut same story
I thing the error is link to eMMC storage, maybe software, maybe hardware.
I plan to try a factory reset via the menu in the parameter to know if I can fix the software issue if it is one but not due to the raw Fairphone firmware.
Do you have some ideas ?
If I can solve it I will have to use the fairphone warranty
EDIT : I have some strange things, all the IO error seems to be from the SD card when i do file operations, but i have no installed app in it. When I soft deconnect it, i can remove every app I want.
Do Android use the SD card like a swap memory or something like that link to the system ?
All the test I do is pointing to a SDcard default. So I think all this sh*t is due to my 4 year old Samsung evo+ 128go starting to completely die. One more e-waste on the planet
I think you have a damaged SD.
You can try to remove it and check your phone properly works.
You could be able to read and copy the SD content to a new one using a PC.
