Hello there !
I’ve got some troubles with twpr and magisk. So I come here hoping that you will be able to solve my problems.
Summary:
I’ve tried to follow this method (How to root the Fairphone 3?), and I’ve fallen in problems. Finally, I’ve used the last comment of this reddit discuss to recover my phone : https://www.reddit.com/r/fairphone/comments/exrxt5/how_to_flash_lineageos_or_any_other_custom_rom_on/
Now I try again this method. And the first time I launch twpr with fastboot, I get a message with mkfs2e and sd-ext :
Formatting SD-EXT using mke2fs...
mke2fs -t -ext4 -b 4096 /dev/block/mmcblk1 3789824
process ended with ERROR:1
Unable to wipe SD-EXT
Unable to wipe /sd-ext
Updating partition details...
...done
(I hope there arn’t typos, I’ve copied manually) I get the same message if I try to wipe in the advanced menu of twpr.
Then, I’ve tried to follow the method with twpr and magisk and I fall in a boot loop with an orange corrupted system message and then I have to make a choice between “Try again” and “Factory data reset”. (and if I push the on/off button, the phone reboots immediately).
Would someone have an idea to help me ?
More precisions :
- On the fastboot screen, its written : “INTERNAL STORAGE SIZE - UNKNOWN”
- OEM is unlock. (of course)
edit1 : To get a woring phone again, i’ll flash again with stock rom A105, and get these following errors :
Invalid sparse file format at header magic
Sending sparse 'vendor_a' 1/2 (519509 KB)
Sending sparse 'system_a' 1/5 (522235 KB)
And the same when I flash the other slot. But that works and I get a working phone again. but i’d like to get a rooted one :’(
