I upgraded my Fairphone to 1.6 today and did the repartitioning. In an attempt (yes, I was stupid but wanted to flash custom system.img builds) to reach the fastboot mode promised here I downloaded the images package and manually flashed recovery.img and boot.img to /dev/recovery and /dev/bootimg respectively. And it totally screwed the partitioning scheme. ADB sideloading the 1.6 or the partition update zip fails with Error: Invalid partition setting 15: ebr2 3d80000:3d00000 on the phone’s screen. I am completely helpless, can’t get a logcat or any other useful information. But I really need my phone. Is there any way you can help me? Thanks in advance!
Many thanks.
I got access to a PC running Windows today. After tons of Windows-ugliness I got SP Flash tool running. For anyone experiencing a similar situation: It wouldn’t let me flash until I chose “Format + Download All”. As a bonus, I can also get into fastboot mode now. I guess it’s part of a non-OTA image, probably updated U-Boot package. However it seems fastboot is also restricted because it will only let me flash official images.
Hi @keesj,
I am trying something along make systemimage; fastboot flash system out/target/product/system.img. It doesn’t work. The phone complains about lost USB connection after downloading for a few seconds and tells me to re-plug the cable. Flashing a custom boot.img works fine, so I am propably just missing some MTK-specific header (can’t find any in factory images though). Should I try flash:raw with a non-sparse image?
@koneu, I am not sure how to do this so you will have to figure it out. I documented the process for the kernel on github and It might contain some hints on how to do things. Trying the raw image is probably a good idea.
For converting between sparse and full images you need the simg2img and img2simg tools that can be found in system/core/libsparce of an Android AOSP checkout. The normal way to create the flashable images is by building the otapackage target so that one will contain a properly formatted .img file.
