to make a partition for the internal storage and the telephon storage - this has worked very well on my wife’s FP 1st. edition.
So I didn´t notice that there was a different storage layout on the new FP.
Now I´ve got an 5GB internal storage and you can imagine I´m pretty angry with myself…
Is there a way to revert this mistake?
The installation of google play store and the other apps by using the widget also doesn´t work
First make a backup.
Then try to run the storage upgrader.
You need FP1 Storage Upgrader* Fairphone_FP1_OS_1G13G_SU_v1_6_OTA_2014-07-31.zip
Instructions and this file can be found on Fairphone Os (multiple versions)
If this doesn’t work then you will need to try the SP Flash tool - this is more advanced, so if you’re uncomfortable doing it then I suggest you contact Fairphone Support directly for further assistance. All details are in this article and you want the section at the bottle for a totally bricked phone. The FP binary files you’ll need for this method are these ones (Note these are for the FP1U i.e. Second Batch phones only)
Thank you chris,
my FP runs alredy with the 1.6 version, by use of the manually reflash method.
But this doesn´t solve the major problem.
I think I need to contact the FP support directly because I´m not that developer guy, I´m more a user ; )
Thank you anyway for your support, this is a very nice forum.
Re Hi,
I get contact to Rick Form the official FP support and he sent me a Kind of
tutorial to get it fixed. By help of an professional I got my Phone
completly fixed, means as it was in the beginning. Im gonna reply bis mail
Tod you.
Cheers
